4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I just cleaned, clay barred, and polished my truck, but now I've got polish marks on the bed rail caps in the textured area. How do you go about removing them. I've tried a tooth brush to no avail.
The only true wax remover is ammonia and you can apply it straight on or mix it 50/50 with water. Put it on and let it sit at least 15 minutes to activate and scrub with some extra elbow grease. Other than that, your local paint stores are sure to have remedies for such, good luck!
Someone mentioned using a product that doesn't cause this, which can be done with great results, but nothing produces as deep of a look as pure carnauba. You can however, tape your trim
