Losing oil pressure??
Old Dec 26, 2009 | 10:27 AM
frofro666's Avatar
frofro666
Default Losing oil pressure??
Hey guys I just noticed, (not sure when this happened) but the oil pressure while driving is only 42psi. It used to be 48psi. Can this be attributed to a dirty oil filter? Also I am using a Fram TG-2 filter which has a high efficiency rate. At idle its 25psi. All these numbers are when the engine is fully warmed up.
Should I be concerned?
Also there is about 5000km on the oil and filter right now.
All reply much appreciated!
Old Dec 26, 2009 | 04:38 PM
Sobomaster's Avatar
Sobomaster
Subscribed for any interesting info that comes from this thread.
Old Dec 26, 2009 | 11:40 PM
Tuono Rider's Avatar
Tuono Rider
Monitor it, but I doubt there is anything wrong.
My runs about 42 to 45 at 1600 rpms constant......temp of oil around 195.
Old Dec 27, 2009 | 09:47 AM
CarGuyOhio's Avatar
CarGuyOhio
As long as the light does not come on you are OK. I never checked mine before but did last night. I was doing almost 75 and had 50psi. Lower speeds of course would have less.
Assume you are running 5W-20 oil as well?
Old Dec 27, 2009 | 10:20 AM
CarterT1975's Avatar
CarterT1975
Mine was down to 19PSI at idle. I checked my oil and it was about a QT low (after 1000 miles). oil pressure was back up to 28PSI after I added oil.
Old Dec 27, 2009 | 12:39 PM
frofro666's Avatar
frofro666
Yip using Castrol GTX 5W-20. By the way I am measuring this at 60mph.
Old Jan 12, 2010 | 12:39 PM
frofro666's Avatar
frofro666
So I took the truck to a dealer and got the oil changed. Bingo. Back up to like 50psi. I think it was the TG-2 filter. I think that filter is too restrictive. I am going to stick with Dodge filters from now on if I do my own changes.
Old Jan 12, 2010 | 10:58 PM
ivaskaj's Avatar
ivaskaj
Take that POS fram off and use a Wix. They are available at NAPA under the NAPA brand. Nothing but the best for my truck.
Old Jan 13, 2010 | 12:23 AM
2010sltsprt's Avatar
2010sltsprt
Wix all the way atleast they dont collapse like a fram wow i just had a bad experience with the fram it collapsed on my grand cherokee
Old Jan 13, 2010 | 10:36 AM
Horseapples's Avatar
Horseapples
the NAPA gold filter is made by Wix, the standard NAPA filters are made by various venders
