Hitch Mounted Parking Sensor
Old Feb 8, 2010 | 11:57 AM
chambers's Avatar
chambers
Originally Posted by davpet
I installed the hitch mounted sensor today, put the wireless thingy in the lighter receptacle, it beeped once when I started it up, but no beeps when backing up or any other time I had it in reverse.. I used the 7 pt trailer socket, do I need to hardwire that square speaker somewhere in the truck, or can I put a 2 prong plug on it and stick it in the 12v outlet and hit the outlet power button?? Is there an on/off switch on the hitch sensor itself??
thanks,
Dave
Watch this video http://www.etrailer.com/tv-demo-audi...or-ASH400.aspx, I think you just need to press the button on the part that plugs into the cigar lighters/power outlet in the cab. Let me know if that fixes it.
Old Feb 8, 2010 | 02:28 PM
davpet's Avatar
davpet
Just saw the video...I'll do it and get back to you all.
thanks,
Dave
Old Feb 8, 2010 | 07:47 PM
davpet's Avatar
davpet
Default Success.
Guys...used a shaved down wooden match...and reset the RF reciever to the hitch mounted sensors...works really well...light flashes as the beeps change speed and intensity.. Should be a cool addition.
Dave
Old Feb 8, 2010 | 07:54 PM
johncarva's Avatar
johncarva
Ok try these instructions .
* Programming: (Fig. B)
To program your receiver
, or an additional or replacement receiver to the sensing unit, the vehicle must be in reverse gear and the ignition switch turned on with the parking brake set. Using a toothpick, or similar non-metal "probe", insert it into programming port and press and hold for at least 5 seconds, then release. Upon releasing the reprogramming button, you will hear one long confirmation chirp. After reprogramming, test the system by slowly backing toward a large object that will be detected in each zone. If you still experience problems, call: (800) 225-6074.
Old Feb 8, 2010 | 07:58 PM
johncarva's Avatar
johncarva
With me I had to reset the receiver, because gave me the same problem but after reseting did work out good.
Old Feb 16, 2010 | 03:49 PM
chambers's Avatar
chambers
My dad got one from etrailer and it's hooked up and working.
Old Feb 16, 2010 | 07:16 PM
72combo's Avatar
72combo
I am so glad that someone else bought the step parking sensors cuz I wanted them but don't like the look of the ones in the bumper, now this just looks like a step, I think I would tap into the wires under the truck though so it does not look so easy to steal. I like the idea it doubles as a step for most people, but I have noticed that people driving pickups are most often over the limit oh well too bad for them LOL. I think I will get one then. Good thread.
Old Feb 16, 2010 | 07:21 PM
72combo's Avatar
72combo
thanks,
Dave
Where is the 2 prong 12 V outlet. If you are thinking about the one on the dash on the passenger side that is 120V not 12 If you want to blow a fuse at minimum you could do what youwanted or possibly see fire. That is like a plug in your house that you can plug a very small appliance like a laptop or small tv or something like that, I don't know the specs but I do know it's well over 12 v
