Payload/Hauling
Old Dec 28, 2009 | 07:03 PM
09RAM4WD's Avatar
09RAM4WD
Default Payload/Hauling
Well i have a question, never hauled anything that weighed alot before. Tomorrow my friend wants me to take him to lowes to pick up some pellets for his wood stove. He needs to get 50 40lb bags, so total weight of like 2,000lbs. Will i be able to take it all in one trip??? Any advice greatly appreciated like i said never hauled anything heavy before, also if anyone has ever gotten these bags there how do they load them into the bed, or do you do it bag by bag. Any help appreciated thanks
Old Dec 28, 2009 | 07:34 PM
topgun's Avatar
topgun
Around here they load the pallet with a fork truck if you buy the whole thing.
2,000 lbs puts you overweight though. I'd split it into 2 trips since your max payload is probably in the 1,600 range which includes occupants and load. a 1500 is considered a 1/2 ton truck meaning you can generally haul about 1/2 ton in the bed. Depends on the engine and gears, who and what is in the cab though to get the exact figure.
Old Dec 28, 2009 | 07:36 PM
RamR/T's Avatar
RamR/T
Passengers/cargo payload - less than 1400
Old Dec 28, 2009 | 07:48 PM
09RAM4WD's Avatar
09RAM4WD
ok guys thanks for the info, i thought it would be to much in one trip..might just have to make two
Old Dec 28, 2009 | 07:51 PM
09RAM4WD's Avatar
09RAM4WD
so if i take half which would be 1,000 lbs plus me 140lbs plus him about 150lbs, should be good then right
Old Dec 28, 2009 | 07:56 PM
tombogue09's Avatar
tombogue09
I say do it, the truck will be leveled when you unload it
Old Dec 28, 2009 | 08:14 PM
topgun's Avatar
topgun
Yes, that sounds like what I would do.
Old Dec 29, 2009 | 09:13 AM
frogslinger's Avatar
frogslinger
That half ton means half a ton of payload is not accurate.... that is what used to be true in about 1985 but half tons are far more capable today.
Even given this, you will be overloaded. My advise would be to go to uhaul and get an open trailer and just tow it... less wear and tear on the truck.
If you do haul the whole ton in your bed I am sure the truck will take it. Ratings are very conservative.
I have in my official capacity been forced to tow a trailer with a 1200 lb tongue weight with a class 4 receiver rated to 600 lbs. (ford f250 diesel)
I have also hauled trailers that are multiple tons over capacity (20+), of course that is a whole different kettle of fish. (Freightliner M915)
Old Dec 29, 2009 | 10:44 AM
switchblade906's Avatar
switchblade906
well idk about you guys but i took a pallet of 55lbs sand blasting sand all in one trip, it wasent that safe because the stearing was alot different but i did drive it 30 miles to where it had to go.......
Old Dec 29, 2009 | 11:56 AM
topgun's Avatar
topgun
Get in a crash overloaded and you will be in deep s..t.
