Old Aug 12, 2015, 02:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
Service Park Assist.............
Old Jan 28, 2010 | 09:31 AM
VALKDRYVER's Avatar
VALKDRYVER
Default Service Park Assist.............
Anyone else seen this message? The light on the dash will not go out when you press the button. First came on after a wash here in frozen South Dakota, so I thought that may have something to do with it. It has not moved for 2 weeks, sitting in the heated garage, so Iam pretty sure that if ice was the problem, it is not there anymore. Taking it in on Monday, but I thought I would check here too, just incase it may be something simple. 2009 Laramie model.
Thanks, Scooby
Old Jan 28, 2010 | 10:24 AM
nolimits's Avatar
nolimits
I'm in SoDak, too, and I get that all the time when snow/ice get on one of the rear sensors. It goes away when the conditions are better. I don't see a way around it, so I ignore it. Normally mine is good after sitting in the garage, maybe there's some residual dirt left behind on yours?
Old Jan 28, 2010 | 02:48 PM
jzld88's Avatar
jzld88
I just took my truck in for this yesterday and they told me that once the sensors detect they are blocked they need to clear the error code on the computer
Old Jan 29, 2010 | 11:56 AM
nolimits's Avatar
nolimits
My error code goes away everytime I turn the key off. It will come back immediately only if the sensor's still blocked. It's possible the code is still stored of course, but it's no longer on the message screen.
Old Jan 29, 2010 | 12:20 PM
jzld88's Avatar
jzld88
Ya most of this winter as soon as my sensors were cleaned it would no longer display it in the messages but for whatever reason this last time the dealer needed to clear it
Old Jan 29, 2010 | 01:20 PM
09RAM4WD's Avatar
09RAM4WD
mine comes on everytime it snows bad and gets dirty or ice on it, goes away by itself everytime when the ice melts or dirt gets cleaned off
Old Jan 29, 2010 | 02:40 PM
Twist's Avatar
Twist
Same here, the dealer told me he has seen the message come on when too much steam is coming out of the tail pipes on the trucks with dual rear exhaust systems.
Old Jan 30, 2010 | 09:05 PM
GMONEY126's Avatar
GMONEY126
I had the same issue...there was a reflash for the park system if I'm not mistaken, maybe check to see if you've received that. Mine acts up after a car wash/freeze but typically goes away after parking in the garage.
Old Feb 2, 2010 | 04:20 PM
rdculus's Avatar
rdculus
im up in canada, i just shut them off for the winter months. most times they are frosted over or too dirty to work. the dual rear exhaust definately exagerates the problem. I had the same issue with my srt grand cherokee
Old Feb 2, 2010 | 04:34 PM
Tizzy1's Avatar
Tizzy1
There is a technical service bulletin for the trucks with dual exhaust to update the software for the park assist module. TSB 08-010-09
