Alarm light in gauge cluster.
Old Jan 29, 2010 | 11:59 PM
cpelton's Avatar
cpelton
Default Alarm light in gauge cluster.
Does the oem alarm light tell you if the alarm was set off? In the manual it says once locked/armed it flashes rapidly for 15 seconds then flashes slowly until disarmed... well just a half hour ago I went out to the truck, unlocked it and jumped in as usual. The alarm light was flashing at me then stayed on solid until I put the key in, I've never seen or noticed this before?
Old Jan 30, 2010 | 11:48 AM
devile's Avatar
devile
i think noticed is the key word here...
Old Jan 30, 2010 | 02:13 PM
cpelton's Avatar
cpelton
Nope I have tried to repeat it and can't. After unlocking the light stays off.
Old Feb 2, 2010 | 04:28 AM
devile's Avatar
devile
hmmm, that's really odd... try rolling your window down, getting out, close door, arm system... you should see the light flash for about 30 seconds... once the flashing slows/stops, reach inside, manually unlock the door, and open the door... does the alarm go off? If not, and your truck apparently has alarm system, i would go see the dealer...
