shift point lag
Old Feb 2, 2010 | 06:14 AM
trashman139's Avatar
trashman139
Default shift point lag
i have a 02 ram and a 09 ram and the transmission between the 2 are totally different i like the 02 better. the 09 feels like i need to have it to the floor in order to get it to shift faster. with it being under warrenty is it covered to have the dealer change it to make it more snappy?
Old Feb 2, 2010 | 07:19 AM
hounddogg's Avatar
hounddogg
Doubt there's anything they could change.
Old Feb 2, 2010 | 07:56 AM
RamR/T's Avatar
RamR/T
Let B&G transform your Hemi! Some available performance options below.
Revise premium fuel timing & WOT fuel tables
Modify idle speed
Cooler engine fan on temp
Cooler transmission overheat on fan temp
Firmer, smoother shifts
No stall air/fuel torque management
No stall timing torque management
Modifiy shift torque management
Modify tip in spark retard
Modify throttle pedal/blade filter
Modify down stream o2 sensors algorithms
Modify A/C off at WOT feature
Modify knock sensor algorithms
Modify closed to open loop time
Modify closed to open loop fuel enrichment curve
Modifiy rev limit
Modifiy top speed
Disable MDS (Who really buys a Hemi Ram to cruise at 55?)
Program fogs with highs
Disable ERM (drifting)
Electric line locker (burnouts)
Ram Air hood
Trick dual exhaust with headers, hi-flow cats, remote control electric exhaust cutouts
Motor/tranny builds, gearing, turbos, blowers, etc.
