305/55/r20
Old Dec 21, 2009 | 03:49 PM
BOWERSFJ's Avatar
BOWERSFJ
Question 305/55/r20
Has anybody tried this tire size ? Pirelli makes it in their ATR Scorpion. It is 33.2" dia with a 12" section width and 11" tread width, so it is about an inch wider than factory. The factory 20" clad wheels are 8" wide with 5.75" backspacing. If I'm going to get the wider tire and aftermarket rims, would it be a good idea to look for something with a little less backspacing to avoid any rubbing issues ?
Old Dec 21, 2009 | 03:53 PM
crod's Avatar
crod
im pretty sure the factory chrome clads are 9" wide. almost positive....
check out this thread mopwr2u has the best write up..... about half way down.
https://dodgeforum.com/forum/4th-gen...-thread-4.html
Old Jan 24, 2010 | 04:36 PM
Gasguzzlr's Avatar
Gasguzzlr
Default yeah, I have...
Just installed them on my 2010 Sport 4X4. I went with BFG AT KO's. No issues at all so far, they look great and I don't see them rubbing anywhere. I had them on my 2006 as well and no probs there either.
Like Crod says, I think the rims are 9", so mounting these tires isn't a problem at all, and from my perspective neither is clearance.
Old Jan 24, 2010 | 05:05 PM
tombogue09's Avatar
tombogue09
pics???
Old Jan 24, 2010 | 05:18 PM
carbonjuicd's Avatar
carbonjuicd
are these tires shorter in height from stock?
Old Jan 24, 2010 | 06:14 PM
CarGuyOhio's Avatar
CarGuyOhio
No, stock tires are also 33"
Old Jan 25, 2010 | 05:14 PM
Dustinmc15's Avatar
Dustinmc15
I have that size on my truck with stock 20s, no issues.
https://dodgeforum.com/forum/4th-gen...-toyo-ats.html
Old Jan 31, 2010 | 10:54 AM
Mortg.Man's Avatar
Mortg.Man
Yeah I had that size on my 03 HemiRam and they were great. I ran the BFG all Terrain TA KO's as well. The are the best winter tire out there. I changed to the TOYO's Proxes for spring/summer.
Now I have my 09 HemiRam and I have to buy them all over again!
Only problem is the BFG's are $375.00 each UGGGHH!!
Mike De.
Old Feb 1, 2010 | 11:45 AM
bohrman44's Avatar
bohrman44
ok so i have the factory 20's on my truck as well and was looking at getting aftermarket rims....20X9's with a -12mm offset......so what your saying is I can take my stock tires off my truck and put them on this new rim setup? cause some said that we have 8" factory rims?
Old Feb 2, 2010 | 09:05 AM
Harmsie's Avatar
Harmsie
There are two different widths of 20" wheels, the standard 20 is 8" wide and the chrome clad 20 is 9" wide.
