Cost of Quad headlamps?
Old Feb 14, 2010 | 12:43 AM
Coolidge's Avatar
Coolidge
Default Cost of Quad headlamps?
Anyone know what it would cost me to buy a set of quad headlamps from Dodge? My truck was supposed to have them as part of the BigHorn package but doesn't. I'm battling with Chrysler to get them for free but I will buy them if I have to.
Old Feb 14, 2010 | 04:12 AM
Revo's Avatar
Revo
Screw buying them if your truck was supposed to have them from the factory fight it out till the end.
Old Feb 14, 2010 | 12:35 PM
1500TRX's Avatar
1500TRX
Not worth, the harness is different as well as the headlamp itself. Buy your self a nice set of bulbs, silver star or PIAA replacements. You actually have a larger reflector than the quad beams.
Old Feb 14, 2010 | 02:33 PM
CarGuyOhio's Avatar
CarGuyOhio
I have them on mine. I think they look better but they are not that bright.
Old Feb 14, 2010 | 08:38 PM
zuiquan1's Avatar
zuiquan1
False. The two harnesses plug together into one and plug into the same harness. I did this on my truck and several others did this as well.
I prefer the look of the quads alot better, I got mine on ebay for cheap....if you try and get them from the dealership you'll be paying ALOT of money.
Old Feb 14, 2010 | 09:39 PM
matt3's Avatar
matt3
I have the Bighorn package and my truck doesn't have quad lights either. Nor does it have puddle lamps on the mirrors. I checked the sticker and it doesn't list them as equipment under the Bighorn package yet some Bighorn's have them. Let us know how it goes. I might do the same thing if your successful.
Old Feb 14, 2010 | 10:37 PM
Coolidge's Avatar
Coolidge
Quad headlamps are an upgrade as part of the Bighorn package. The dealer had 2 quad cab Bighorn trucks on the lot one had quad headlamps and mine with dual headlamps yet both Bighorn packages were $2,400 hmmm something fishy about that.
The dealer called Chyrsler, they confirmed it should have quad headlamps and said it was a mis-build. The dealer then lied to me and said there was no way to swap the headlamps claiming the wiring was completely different. Then Chrysler customer service lied to me claiming the truck is supposed to have dual headlamps. I said then explain why the specs for my truck on the Dodge web site clearly notes my truck is supposed to have Quad headlamps. They kicked the issue up to corporate at this point.
Old Feb 15, 2010 | 12:58 AM
72combo's Avatar
72combo
You are looking at the options available! Did you order all those options. Check what comes standard, you can't look at the options section and tell them they have to give you them.
