Truck Campers
Old Feb 17, 2010 | 12:09 PM
thirtydaZe's Avatar
thirtydaZe
Default Truck Campers
Have a 2009 crew cab.
Anyone ever see one with a camper in the bed? Do they even make 'em that small?
Any recommendations as to where to shop?
Old Feb 17, 2010 | 01:11 PM
cpelton's Avatar
cpelton
I wouldn't put a camper in a 1500 unless it was one of those truck bed tents! You'd have a hard time getting the CofG of the camper ahead of the rear wheels as well.
Old Feb 17, 2010 | 01:28 PM
TI 3VOM's Avatar
TI 3VOM
Yup, I would check weight limits and centres of gravity. You could put an 8 ft camper back there with only 1.5ft of overhang but the COG would be behind the wheels.... Lots of weight on the back and skying the front end....
Old Feb 17, 2010 | 01:50 PM
oldjeep's Avatar
oldjeep
http://www.dodge.com/bodybuilder/2009/docs/dr/cgrcc.pdf
If you scroll to the bottom you will see that they don't recommend a camper for any crecab configuration
Old Feb 17, 2010 | 05:27 PM
Ironhead's Avatar
Ironhead
Dodge has been known to do that on most of their trucks. They put a sheet in the glove box that says not recommended for truck campers - then goes on to show you how to load the camper. Go figure! Back to the original question, you will be hard pressed to find a camper with the center of gravity over or in front of the rear wheels. You will have to look for one that is made for a short bed and check the COG.
Old Feb 17, 2010 | 05:48 PM
thirtydaZe's Avatar
thirtydaZe
cool enough then, didn't know much about them. i know one thing for sure, damn they are expensive!
Old Feb 17, 2010 | 07:19 PM
Indianadodge's Avatar
Indianadodge
When you say camper top do you mean this?
http://www.blazerchalet.com/1383park1.jpg
or this
http://media.truckblog.com/ai/2007/1450.jpg
Old Feb 17, 2010 | 07:57 PM
TI 3VOM's Avatar
TI 3VOM
Something like this may work.....
http://www.palominorv.com/site/defau...e=10&series=TC
Fairly light wieght but you would still need to measrue COG. They list it at 25", you would need to measure back from the front of your box and see where that sits.....
