09 2WD level kit
Old May 31, 2010 | 07:26 AM
  #21
jbgp1200's Avatar
jbgp1200
KC09103BK
Comfort Ride
DODGE RAM 94-09 1500 2WD, 94-10 2500 /3500 1.5" BUDGET BOOST
Old Jun 1, 2010 | 06:38 AM
  #22
BULLRAM's Avatar
BULLRAM
gvillefloridar1
when my 6 inch CST 2WD lift came in it has CHEVY coil spring spacers in it, they are the same diameter as my 09 Dodge Daystars, 1.5 kit but , they are 2 inch, I will post up some pictures when I install the lift to show the difference of the daystars 1.5's , and the 2 inch spacers
Old Jun 1, 2010 | 03:58 PM
  #23
gvillefloridar1's Avatar
gvillefloridar1
Originally Posted by BULLRAM
gvillefloridar1
Do you know where i can just get those spacers?
Old Jun 1, 2010 | 09:03 PM
  #24
BULLRAIDER's Avatar
BULLRAIDER
I can give you the number ,but as I stated I havnt put them in yet to see the difference, let me put them in before you spend your money, this weekend I will know, they look to me the same, but I wont say that for sure till I install these ,if you want an almost level,and cheap,go with the daystar 1.5 budget boost, or I will sell you mine when I have changed when you measure these, rule of thumb is double your reading when complete, these are 2 inches total height,sitting on a table, then down to where the coil sits , it is exactly 1 inch, so subtract, and you get 1 inch, double that and it is 2 inch lift coil spacer, I have found the manufacturers only make certain heights, I have bought 4 different sets, all said they were 2 inch lift, on a crew cab with a HEMI, they were NOT 2 inch lift, the daystar 1.5 are exactly 1.5 inch lift on my truck, which does NOT level the truck. Also the rubber isolator can be used for another 1/4 inch lift, in most cases
PROCOMP ----PLG 09101
