audio questions
Old Mar 13, 2010 | 01:45 AM
RGVram99's Avatar
RGVram99
Originally Posted by BigTexMarine
beware when swapping the 6x9's, the speakers are apparently super thin and replacements wont fit. you may have to do what i did and go with 6 1/2's with a 6x9 plate adapter.
Yeah I read that too, if you try to install 6x9's w/ large magnet/frames you will have to modify the door opening. I would look for some decent 2/3 way pioneers with shallow mounts. No need to go with monster high power 6x9's if I am going to run them off the factory deck.
Old Mar 13, 2010 | 10:20 AM
72combo's Avatar
72combo
The front speakers are not full range in the truck I think there is a crossover or something, the front speakers I hear are a sort of component deal now, so you can put some better component speaker and put the tweeter up in the dash or eliminate those and put the tweeter in the door within the 18 inches or whatever they say sounds good. This could be all BS info but it is from a tech at a dealership. Just food for thought. I thought there was a plug and play kicker system with speakers and an amp that just plugs in under the dash on the drivers side. and you can get a kicker amp and sub also plug and play supposedly the wires are back there already? Never looked yet. If anyone knows about the kicker plug and play setup chime in please. or PM me
Old Jul 29, 2010 | 06:13 PM
ChuckWag78's Avatar
ChuckWag78
Originally Posted by jrtx
Thanks for the replies and advice. I have decided to just order the Kicker upgrade for the front doors and dash. This is all just too much of a headache, I think I was oversold on speakers. It makes sense that they don't sound good cause they're so underpowered by the factory amp. I think the Kickers are better matched to the amp and will sound better. I'm not an audiophile by any means, I just want a better sound and some thump. Sooo........anyone in the market for some Vibe Space 6's????? I'm sure they sound great w the right amp.
Hey jrtx,
How are you liking the Kicker upgrade? Was it truly plug in play like the descripion states?
