Custom Front Bumper Is On
Old Mar 11, 2010 | 03:25 PM
4x4ramrod's Avatar
4x4ramrod
Default Custom Front Bumper Is On
I had a buddy of mine that i work with build me a custom bumper after i wrecked the truck. it wasnt bad, just the bumper took at hit so i needed to do something and this is what we came up with. i am working on getting a winch and tires just running out of $$$$. u can see some of his other stuff on his youtube channel, its in my sig. hope yall like it
http://www.youtube.com/watch?v=LDM8qtUYtVQ
Old Mar 11, 2010 | 03:29 PM
oldjeep's Avatar
oldjeep
Looks decent, my only concern would be using those tow points. Big beefy metal up until the plates that actually get bolted to the truck frame. How thick are those plates?
Old Mar 11, 2010 | 03:35 PM
4x4ramrod's Avatar
4x4ramrod
they are 1/8". i looked at alot of other aftermarket bumpers and this is a common size. its the same exact thickness as the plate on the truck from the factory. the guy building it wanted to use 3/4'' but that is just too big.
Old Mar 11, 2010 | 03:43 PM
TI 3VOM's Avatar
TI 3VOM
It's pretty hard with all the curves on these newer trucks to make a bumper that works. That looks pretty damn good. Well done and props to your friend!
Old Mar 11, 2010 | 03:44 PM
oldjeep's Avatar
oldjeep
Except that the factory bumper does not contain or support the tow hooks (just shares 2 of the frame bolts). Might be worth having him build in a tie in to the large bolt on the bottom of the frame that the factory tow hooks use.
Old Mar 11, 2010 | 05:07 PM
4x4ramrod's Avatar
4x4ramrod
i didnt have factory tow hooks. the ones on the new bumper are lined up with the frame of the truck and its all welded together. ill let u know when i use them to let u know if it works or not. with as much time and money i have in this i hope they dont give.
Old Mar 11, 2010 | 06:44 PM
72combo's Avatar
72combo
Unless you are trying to pull something a lot bigger than you I think you should be safe that think looks heavy duty, I too would be concerned how it is mounted but from how that turned out I bet the guy who built it knows what he is doing.
Now what about painting it the same colour as your truck? What is the rectangular hole in the center for?
Old Mar 11, 2010 | 06:51 PM
oldjeep's Avatar
oldjeep
It says winch bumper, so I'm going to guess it's for a winch. Mounting pattern looks a little odd, so I'm not sure what kind.
Old Mar 11, 2010 | 07:56 PM
464jet's Avatar
464jet
Nice job for sure.I'm a welder by trade and that bumper looks good.Old jeep has a good point about the mounting points but you will probably be ok if you dont stress it beyond limits.I like the design. Your buddy did a nice job!
Old Mar 12, 2010 | 01:16 PM
4x4ramrod's Avatar
4x4ramrod
i would like to paint it the same color as the truck but dont want to spend the money on it then go off road and scratch it. so its spray paint for now so i can touch it up if need be. and the hole in the middle is for a winch. im getting the ramsey 8500lb. i used a roller fairlead from my buddy that has a ramsey so i know it would fit when i get mine. but thanks for the comments and hopefully soon i will have some pics of it being used
