help me pick tires. (something close to 285/65/20)
Old Apr 5, 2010 | 06:54 PM
010 Sport's Avatar
010 Sport
Oh and I've heard good things about the toyo open country mt's but have no knowledge of the size availability
Old Apr 5, 2010 | 10:30 PM
DodgeNweave's Avatar
DodgeNweave
Get Nitto trail grapplers. Ive read some rave reviews on them. Im getting the 295/70r18 this weekend, 34.5" x 11.7" except I'll be getting -12 offset wheels also. you might need a 1/4 or 1/2 inch spacer. might be close tho. If i remember right, stock tire width is like 10.8 and you have about 3/4" clearance on the upper control arm. Also I have a TRX4 which is 3/4" higher in the front then yours. I think you could fit it without much problem. Good luck
Old Apr 6, 2010 | 07:41 AM
Frouburg's Avatar
Frouburg
In regards to rim width, 9" is sufficient to run 12.5" wide tires (i used to run 12.5" on 8 rims on my wrangler and currently have 33x15.5 Mickey Thompson Baja Claws on 10" wide rims with no issues).
So, for the tire size of 285/60/R20, what size tire is that? Also, I see that cwoposey is also running 20" XD rims, which I assume has a greater offset, right?
Old Apr 6, 2010 | 08:24 AM
MTtruckr's Avatar
MTtruckr
tried to upload a pic of that setup but don't know how
Old Apr 6, 2010 | 05:08 PM
jake09's Avatar
jake09
mine with 285/65s...could go with a certain 12.50s if you wanted
http://s562.photobucket.com/home/jakew09/index
Old Apr 6, 2010 | 05:11 PM
jake09's Avatar
jake09
if it doesnt work again just click link
Attachment 8311
Old Apr 6, 2010 | 10:13 PM
DodgeNweave
I happened across this on google, couldnt get the pic to load. But check this guys truck out! It looks freakin awesome, and appears to have no lift. Tires are 35"12.5"r20 Toyo MT, and wheels are Atx Artillery 20x9 -12 offset. I might be goin back to my first choice which was the black artillerys
http://www.f150online.com/forums/mem...aded-gills.jpg[IMG]file:///C:/Users/DARKNE%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/DARKNE%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
http://images.google.com/imgres?imgu...26tbs%3Disch:1
Old Apr 7, 2010 | 08:09 AM
Frouburg's Avatar
Frouburg
Jake09, i love your truck. for your leveling kit, did your dealer give you any crap with your warranty? I have the same truck, and think I will be going with your same setup.
Old Apr 7, 2010 | 08:25 AM
matt3's Avatar
matt3
Nice! I think I'm gonna go with the same tires too.
Old Apr 7, 2010 | 10:45 AM
jake09's Avatar
jake09
thanks...haven't had any problems with any dealers..(been to about 3)..rides just like stock though and love the tires
