Y-Pipe
Old Mar 23, 2010 | 08:30 PM
ten6's Avatar
ten6
Default Y-Pipe
Has anyone swapped there Y-pipe out, for one that is not as restrictive as the stock one? I know there has been some talk, but that was months ago.
-Steve
Old Mar 24, 2010 | 12:22 PM
DesertHemi2500's Avatar
DesertHemi2500
The stock Y pipe is minimally restrictive to say the least, I don't think it's a worthwhile mod unless you got money to blow on 1hp gains.
Old Mar 24, 2010 | 06:03 PM
chambers's Avatar
chambers
The stock y-pipe is the biggest POS I've ever seen (take 2 pipes and crush them to fit into a slightly bigger one) and plenty of guys have swapped it on their 3rd gen's. If you're already doing your exhaust then it's a good time to get one and have it put on.
Old Mar 24, 2010 | 09:09 PM
RamPhreak's Avatar
RamPhreak
That Y is quite restrictive if you compare it to how is SHOULD be. Although it doesn't yield massive gains to just change it, it definitely helps if you are making other upgrades.
Old Mar 24, 2010 | 09:50 PM
War Horse's Avatar
War Horse
So, the Y in question is the one up front where the pipes come down off the exhaust manifolds and go into a single pipe?
Old Mar 24, 2010 | 10:08 PM
M15's Avatar
M15
That's it.
Old Mar 24, 2010 | 10:09 PM
TorRedOrv0436's Avatar
TorRedOrv0436
I did mine..very happy with it...it's a must if you get a superchips...
Old Mar 24, 2010 | 10:21 PM
dustin72's Avatar
dustin72
Did you get it custom built or is someone from the aftermarket making them?
Old Mar 25, 2010 | 12:12 PM
ten6's Avatar
ten6
TorRedOrv0436,
Was yours custom, or did you buy aftermarket? Also, how much did it run you? Any issues with the dealer?
Thanks.
-Steve
Old Mar 27, 2010 | 07:53 PM
TorRedOrv0436
Got it from Moe's Performance its a Magnaflow $29.99 Had it installed for 120 bucks
