Using Ipod without uconnect on 2010 RAM
Old Mar 29, 2010 | 11:04 AM
mhobart2's Avatar
mhobart2
Default Using Ipod without uconnect on 2010 RAM
Hi everyone,
Just bought a 2010 Dodge RAM 1500 without the UCONNECT. The manual makes it sound like I should be able to just buy the Ipod cable and I should be able to control it through the head unit. Is that true? Or do I need to get the UCONNECT module as well? The parts dept can't give me a straight answer. Any help is greatly appreciated. Thanks!
Matt
Old Mar 29, 2010 | 12:16 PM
topgun's Avatar
topgun
I think your only option without U Connect is to go through the AUX plug so no physical control of the Ipod from the radio.
Old Mar 29, 2010 | 12:27 PM
CarterT1975's Avatar
CarterT1975
+1....
Old Mar 29, 2010 | 12:37 PM
P90XCoach's Avatar
P90XCoach
Do you have the REN or RER radio? If you have one of those, you should be able to buy the i-Pod interface cable and control it through the radio. It is the best thing since sliced bread.
Old Mar 29, 2010 | 12:56 PM
topgun's Avatar
topgun
The RER has the U Connect built in but the REN does not. So where would you plug the cable into?
Old Mar 29, 2010 | 12:57 PM
jawsdc's Avatar
jawsdc
from my understanding, you will need a uconnect module. the ipod cord plugs into it, not the head unit.
the manufacturer of the head unit has changed since the '09 models but not the schematics, form what i understand.
Old Mar 29, 2010 | 01:09 PM
CaliAthlete's Avatar
CaliAthlete
Course, if you're going to buy the seperate module, might just want to spring for the allgig/mygig setup...
mhobart2's Avatar
mhobart2
Thanks everyone for the quick replies! I have the RES radio, so I guess I'll have to get the unconnect module anyway. They said the truck is prewired for it, it just doesn't have the module. Oh well, might just be worth looking into an aftermarket navi with the ipod hookup already included. Thanks again!
Old Mar 29, 2010 | 01:59 PM
cpelton's Avatar
cpelton
better off to get the RER Headunit, it has the module built in then all you need is the cable.. you won't have the mic installed either so you'll have to get that if you want bluetooth. Plus you get nav
Old Mar 29, 2010 | 02:48 PM
mhobart2's Avatar
mhobart2
If I get the RER head unit do I need to get a different bezel or anything? Or will it bolt right in? Besides that, the only other item I'll need is the Ipod cable?
