Need Input on Rear Diff
Old Apr 20, 2010 | 12:51 PM
  #21
MiRamDriver's Avatar
MiRamDriver
Originally Posted by Roy444
Seriously??? Maybe for a 2wd but you missed one important detail Captain Obvious... it is a '4x4'!! Simply rotate your dial to 4h and voila! I actually think it is stupid to pay extra $$$ for a LSD when you have a 4wd.
I think that you need to do a bit more research. The 4x4 switch doesnt mean that all of a sudden all 4 wheels are working. If you have an open rear end you still will only have 1 rear tire turning and on 1/2 tons the front diff can only be open, so you only have 2 wheel drive while locked in 4x4. If you have a LSD rear end then you have 3 wheel drive.
LSD makes a HUGE difference in 4x4.
Old Apr 20, 2010 | 01:01 PM
  #22
oldjeep's Avatar
oldjeep
Sort of. Having an LSD means that you are more likely to have 3 wheel drive. LSD's don't ever really lock, and if you have one of the wheels fully off the ground its unlikely that the one on the ground will get power unless the traction control also kicks in and brakes the wheel in the air.
Old Apr 20, 2010 | 01:10 PM
  #23
MiRamDriver
I've never had a problem with mine locking in any vehicle that I've owned. From what I have heard simply putting your foot on the brake pedal with your foot on the gas as well will cause enough resistance for both tires to spin. If it was a big concern then I would upgrade to a DTT, but in the end having an LSD is MUCH better than going without.
Old Apr 20, 2010 | 02:38 PM
  #24
Roy444's Avatar
Roy444
I'm fully aware of how a 4x4 works and have owned/driven several- both with LSD and without. I will concur that I do not have to worry about driving in snow so maybe a 4x4 with LSD helps in that situation (???), but in all of my years as a hunting guide on several South/Central Texas ranches I've NEVER had a problem getting where I needed to go with an open diff 4x4 nor did I notice much of a difference between a LSD and an open diff. To each their own.
Happy trails.
Old Apr 23, 2010 | 01:02 PM
  #25
IFD31's Avatar
IFD31
Default ARB lockers
Well I had decided that I was goint to regear my 2001 to 4:10 and add a air locker to the rear but to my suprise the locker is not available for the 9.25. So I am back to looking at the Detroit Locker. Any opinions?
Old Apr 23, 2010 | 04:31 PM
  #26
hounddogg's Avatar
hounddogg
Small incline and wet fescue grass and a horse trailer is enough to do it here.Type of tire does make a difference but my tire of choice has always been a highway tread since thats where my trucks are usually driven.
