Firestone Ride-Rite Bags
Old Jan 31, 2011 | 11:07 AM
  #61
05Dakotaho's Avatar
05Dakotaho
Had to cut mine out with a sharp razor knife. In order to replace with Airlift 1000, had to pull the springs out to install the new bags so I could have avoided the cutting of the firestones.
Pulling the springs out was easy after removing the lower shock mount bolts.
Old Jan 31, 2011 | 11:38 AM
  #62
5.7x28mm's Avatar
5.7x28mm
Originally Posted by newram2010
WARNING TO HE(or she) WHO RIDES IN THE COOOOLD haha.. uhhh this sucks lol
it was easy to get them in, but... how do i get em out now? its been pretty friggin cold here, the other day i loaded the truck bed down with wood for the ice shack, then all while i was driving down the back road it was hitting hard.. bang bang bang over every semi large bump or whoop.... upon further inspection later that week.... voila!
uhh soon as i figure out how to add pictures...
Dude, that sucks! What pressure were you running these at when it happened?
Old Jan 31, 2011 | 02:19 PM
  #63
yotaman96's Avatar
yotaman96
I have my air lift 1000 here just waiting for me to install it. The spacers look small enough to slide in the spring without taking the spring out. Wonder if they redesigned them?
Old Jan 31, 2011 | 02:30 PM
  #64
pdavis53's Avatar
pdavis53
Man it is wicked easy to install. I simply jacked up the side I wanted to work on and put a Jack under the frame, I removed the tire then I jacked up the axle and removed the lower shock bolt and the sway bar control bolt and relaxed the jack so the axle came down. I was then able to simply pull the spring out and install the bag. Installation required a long breaker bar for leverage to get the spring over the little knuckle on the axle. Total installation was about an hour. It honestly took me longer to setup an cleanup then it did to do the job. Very easy to install and not worth the headache of trying to force the bag through the spring. Goos luck
Old Jan 31, 2011 | 02:32 PM
  #65
05Dakotaho's Avatar
05Dakotaho
I could not get the Airlift bags folded small enough to fit between the coils. The firestones went in easy.
Old Jan 31, 2011 | 02:54 PM
  #66
yotaman96's Avatar
yotaman96
I have access to a lift, but my car is on it right now. I'm planning on waiting until my car can be moved to install this. I also have an on-board compressor that I'm going to install. I had the springs out of the truck not to long ago when I put my front 2" leveling kit on and 1" rear.
Old Jan 31, 2011 | 09:41 PM
  #67
newram2010's Avatar
newram2010
those bags sound much better, iv done a little reading about them but not much.. im going to check out the forum right now, guess thats the way ill have to go..... i didnt have much air in them when this happen.. 20 pounds rings a bell??? when not in use i ussually let hte air down to 15-20 so it wouldnt effect the normal operation ride. you would think firestone would atleest tell u ** not for sure in temperatures below such n such*** but i guess why would u advertise that they suck? lol.. i shoulda asked i suppose.... lesson learned haha
Old Feb 1, 2011 | 12:41 PM
  #68
Patsfan's Avatar
Patsfan
I'm looking at the Firestone 4185 or Air Lift 1000. Why did you change? I noticed the Air Lift has a max psi of 50 compared to 35 for the Firestones. Anybody know the benefit of this or any other reasons to pick one over the other. The Air Lifts are about $10 more where I am, so it's not a cost factor. I'm also considering a front/rear level kit, so pulling the rear spring would have to be done anyway. I might as well do everything @ once and save some time/labour.
