Keyless Go Push Button Start Installed (pics)
Old Apr 22, 2010 | 05:39 PM
cpelton's Avatar
cpelton
can you post all necessary part #s to do this so I can take it directly to the service dept.
And how does it work to go into acc. then start/run? do you have to push it twice?
Old Apr 22, 2010 | 05:44 PM
RamR/T's Avatar
RamR/T
see post #1
Old Apr 22, 2010 | 05:48 PM
shadowsnake6666's Avatar
shadowsnake6666
Originally Posted by RamR/T
Far as I know only the Keyless Go™ fobit was required. He also set my EVIC to disable MDS/ESP/rev limiter if desired, and keep fogs on with highs. Knows his way around StarSCAN®.
can you post pics of the evic my tech will probably do it if i can prove that i can be done
Old Apr 22, 2010 | 05:54 PM
RamR/T's Avatar
RamR/T
see post #1
Old Apr 22, 2010 | 06:27 PM
TI 3VOM's Avatar
TI 3VOM
Can you double check with him what was needed? From what I have read elsewhere it is the button, fobs, new pem, antenas, etc. Not quite so simple, but still could be worthwhile.
Old Apr 22, 2010 | 06:37 PM
SmittySLT's Avatar
SmittySLT
I need this! Hate the key fob....
Old Apr 22, 2010 | 06:42 PM
tombogue09's Avatar
tombogue09
I can see it now......the look on my service reps face after I walk in with this button wanting the truck programmed to work with it.
We need instructions on how to get the dealer to do this if it is possible.
zuiquan1's Avatar
zuiquan1
I got this from one of the Challenger forums, don't know what would differ with the RAM-
Originally Posted by MOPAR OR NO CAR
Parts you will need:
Keyless Go Key Fobs (05026457AE) 5 button FOB (this FOB has remote start and is the fob for the SRT8)
OR
You could also use part #05026567AE, this is a 4 button FOB, it does not include the remote start feature. (Remote start can also be added easily, you just need the proper Hood switch (Mopar $20) and then program the Cars computer (TIPM) for remote start.
A couple notes about FOBIKS. Once they have been married to a car, they cannot be married to another WIN. It will not work. It changes the programming information inside the FOBIK as well and it will never ba able to be used with another WIN. Be aware of that if you intend to buy a used FOBIK as you will not be able to program it to your car. You must only use Virgin FOBIKS. There is a way to "de-kit" fobiks and return them to a virgin status, but you have to have the right software, and a test box that will program the key. This is not something even a dealership can do. Also, the WIN will accept up to 8 FOBIKS total, so you can keep your 2 original FOBIKS, and then add up to 6 more, or erase your original FOBIKS and program up to 8 new ones. If you opt to keep your original 2 programmed to the car, they will never work with Keyless Go, but they will still perform as they do now. Only the New Keyless go FOBIKS will allow you to start the car with the Start/Stop Button (SSB).
(2) LF Antennas (05026444XX) XX is the revision, I am not sure of the current revision, but any will work.
(1) PEM (Passive Entry Module) (05026443AF).
(1) SSB (Start/Stop Button) (1FU931X9XX).
Recap of parts needed:
(1) WIN - Your current WIN is fine.
(1) PEM
(1) SSB
(2 or more) KG Fobiks (4 or 5 button, with or withour remote start function)
(2) LF antennas
Step 2: Install the modules:
WIN
If you choose to keep your existing WIN, then skip this step. However to program new FOBIKS to your current WIN, you will need to know your PIN number. You should have gotten a card with your car when you purchased it that has your PIN number on it. It is probably with your owners manual. That will have a 4 digit PIN. It is possible that you did not get it though, as I did not with my car, but don't despair, the dealership can look up this number and get it based on your VIN number. The dealership uses the number when getting security access to the WIN to program new FOBIKS.
If you choose to go with a new WIN, then it will be a virgin WIN, and the PIN will be 0000, always.
PEM
Install the PEM. Remove your glove box, and look around under there. he harness connector for the PEM is under the dash, up behind the glove compartment area. If you are unable to locate the connector, don't despair, I will explain later where to connect if you have no connector (As in the SE).
LF Antennas
The Keyless Go uses 2 LF antennas. 1 is located near the PEM, behind the glove box area. There should be a harness connector there. The other goes under the back seat. There should be another connector there as well.
OK. That's it for installation, it should be pretty easy to do, and it won't take too long.
how to activate the system and program the new FOBIKS.
That needs to be done with the StarScan tool, or star mobile. With the StarMobile tool, the tech can come right to your house and do this. It will take about 15 minutes to do this either way. Not all dealerships have the StarMobile, so call first and see if they can do it. All they have to do is connect to your OBDII connector, then set you up.
Step 3: Activate the system and program the KG FOBIKS.
All the next steps need to be performed using a StarSCAN or StarMobile tool. This just connects to the vehicles OBDII port. Any dealership with this tool can perform this, however, bear in mind that this system is very new, and most dealerships do not have much experience with it yet, so it might be a good idea to bring these instructions with you to make sure they complete all the necessary steps. If done properly, it will only take about 10 kinutes to do this.
OK. Now everything should be installed, but the car does not yet know that the PEM is there. Until it knows that the PEM is installed, it won't know to route CAN messages to and from it, and it won't even see it.
1. SET the TPIM to see the PEM.
With the StartScan or StartMobile connected to the vehicle, At the main screen, select the ECU View button.
The next screen will show all the ECU's in the vehicle.
Select the TIPMCGW ECU.
Next, Select the TIPMCGW with the green checkmark next to it.
Next select the button Read/Write Data.
Select the row Programmed ECUs: Cabin Network.
Scroll down to PEM, and change it from Not Set to SET. This will enable the PEM in the vehicle.
(Note: as long as you are at this point, you can also enable Remote Start if your vehicle does not have that option set as well. Just hit the back button and go back to Read/Write Items. Select the row Vehicle Config 1, and then scroll down to the row Remote Start Present, and change that value from Not Set to SET. Go Back again, and select the row TIPM Configurable Inputs. Select the row Reconfig Input#4 (B10) and change that value from Not Present to HoodAjar - Analog. That's it. The vehicle will now work with remote start once you install the hood switch, which you can get from MOPAR for around $19)
Now the vehicle will see the PEM.
2. Program New FOBIKs to the WIN.
With the StarScan or StarMobile, go to the Select ECU screen again.
Select the ECU called WCM. Now select the row with the green checkmark.
At this screen , ECU Overview - WCM, select the button called More Options.
Next select the Button, Onboard Routines. This will bring up a list of special routines for the WIN.
Next the tech needs to click the button called Session Control, Select Extended Diagnostics Session, then click Start. (A Sparkplug Icon will appear next to Tester Present, No response required. Close the window.
Next click the button ECU Unlock, select the number 3, then click Unlock. Close that window.
(Note: Once you have unlocked the WIN with security level 3, you will have 60 secods to complete the programming procedure, and then the security access will turn off. For this reason, you will usually have to repeat this process for each FOB to be programmed)
Now that you have gained security access, If you have installed a new WIN, the new WIN will learn the vehicle configuration from the TIPM.
Now select the row PIN and click the Start buitton. Click on Edit Item and enter your PIN. (0000 if a virgin WIN). then click OK. Then click Start to send the PIN to the WIN.
(Optional: If you intend to replace ALL FOBIKS, at this point select the row ERASE Programmed Keys/FOBS, then select Start. Once the erase is complete, the cluster will chime.)
Click the row Programming Mode, then click Start. A window will open, select the row, Entry Option then Edit Item. Select PROGRAM KEY, then click OK.
Insert the virgin FOBIK into the WIN, turn it to the RUN position. The SKIM light on the IP will go from solid to off and the cluster will chime once the WIN has learned the FOBIK.
If more than 60 seconds have passed, you will need to go back through the procedure again to start programming mode again. (Unlock ECU, Enter PIN, Enter programming mode.)
Do this until all your new FOBIKS have been programmed to the WIN (8 FOBIKS max)
3. Activate the PEM.
With the StarScan or StarMobile tool, go to the Select ECU screen and select PEM.
Select the row with the green checkmark.
Next screen, select the More Options button.
Next screen, select the Onboard Routines button.
Next screen, select the Session Control button, select Extended Diagnostic Session then click Start. (A sparkplug icon will appear next to Tester present, no response required), Close window.
Next select the button ECU Unlock. Select the number 3, then click the button Unlock.
The PEM is now unlocked and security access has been granted. The PEM will automatically learn the vehicle configuration.
Leave the PEM in security access mode to perform the next step.
4. Transfer the FOBIK information from the WIN to the PEM.
With the StarScan or StarMobile tool, Go back to the Select ECU screen.
Select the row WCM.
Next select the WCM with the green checkmark next to it.
Next screen select the Onboard Routines button.
Once again, select session control, Select EXTENDED DIAGNOSTIC SESSION, and then click START. (A spark plug ICON will appear next to TESTER PRESENT, No Response Required.) Close that window.
Next select the ECU Unlock button, and select 3, then Unlock. Under Onboard routines, select the row PIN, and then click the button START. Click on the PIN row, then click the button EDIT ITEM, enter your PIN then click OK (Almost forgot, The PIN you enter here will be 0000, because this is a virgin PEM. If it had been installed at the factory, it would be the same as the PIN in the WIN). Click START to send the PIN to the WIN.
Now, under Onboard Routines, select the row called Transfer Secret Key and Key IDs (Passive Entry Module). Then click Start.
Once that routine completes. you are done!
Now the system should be working.
That should be all there is to it.
There was actually an H29 recall to flash the older WINs which actually brings them up to the current version.
To get the system to work with the SE, you have to flash the WIN with the correct software flash. This software is not available to dealers, as it is still not an option for the SE. I have some connections at Chrysler, and was able to get it, but the dealerships cannot. If you had the file, then the dealership would be able to load it into the startscan and then flash away. This is necessary to allow the WIN to send the proper signal to the 3.5L to start. All current WIN modules will only send the command to start an 8Cyl engine with a Start/Stop Button.
The PEM wiring for the antenna's does not exist in the SE, but it is easily added. The PEM has 2 connectors on it. The first you will need to connect 4 wires, +12, GND, CAN+ and CAN-. Power and Ground can be easily gotten at the 12V power point inside the center console power point. For CAN, There are 2 places you can connect. 1 is the radio, the other is the HVAC controls. The easiest place is the HVAC. The CAN+ goes to the White/Orange wire, the CAN- goes to the White wire. Just splice into those wires and it will now be on the bus.
To add the antennas is easy as well. The other PEM connector will hold up to 5 antennas, but for Keyless Go, only 2 are used, Antenna 2 and Antenna 3. One will go near the PEM (Behing the Glove Box is a good location since you want 1 to be up front) and the other antenna needs to go behind you (Under the rear passenger seat is a good spot and you can run the wiring beneath the passenger side kick plate, you will never know it's there).
Once the PEM and antennas are installed, use the star tool to change the PEM to "SET" as I described in an earlier post and follow the other instructions to activate everything. The dealership should know how to do all this, as it will be the same for an SRT8 or RT with the keyless go.
Also P/N for the actual button-
82211026AC (don't know if this is correct)
"note-Information received from www.challengerForumz.com"
Old Apr 22, 2010 | 06:53 PM
tombogue09's Avatar
tombogue09
I don't see how this could work with these trucks without these extra parts. Why would our trucks have the antennas that are necessary for this to work?
Old Apr 22, 2010 | 07:33 PM
cpelton's Avatar
cpelton
I agree, I too had been following the challenger forum thread.
