For you northern guys with HIDs
Old Apr 25, 2010 | 11:22 PM
SmittySLT's Avatar
SmittySLT
Default For you northern guys with HIDs
Anyone have problems with an HID (or 2) not lighting off on cold mornings? Once the temperature gets below 40 here I have to restart at least one of mine. They start...then go out. Tried cancelers and caps. New relay too. Still wont light off the first time if its cold.
But springs here and they light almost every morning now. Except for the mornings under 40.
Just wondering if anyone else has had this problem with their kit.
I'm getting ready to try another kit.
PS...I'm not using the kit offered by Unique-Coatings. Just looks that way in my signature.
Old Apr 26, 2010 | 12:01 AM
cpelton's Avatar
cpelton
negative! ive never had problems with any of my HID's in the cold, even @ -20*c
Old Apr 26, 2010 | 04:28 PM
JC1390's Avatar
JC1390
ive had problems with mine just like you said...mine sometimes will flicker...i noticed that when they flicker and you flash your high beams they'll come on.
Old Apr 26, 2010 | 05:04 PM
zevrosenthal's Avatar
zevrosenthal
a couple of times all winter one of them wouldn't like but, if I shut off the car and started it back up, it lit fine. I tired to troubleshoot but it's so infrequent and there doesn't seem to be any pattern. I hadn't thought about the cold but that might be it. I got mine from HIDextra.com. Other than those couple of times, they have worked great.
Old Apr 26, 2010 | 05:07 PM
cpelton's Avatar
cpelton
I had a ballast go and had to replace it, but I think that was unrelated to weather.
Old May 15, 2010 | 05:27 AM
jzld88's Avatar
jzld88
I've never had a weather related problem with mine blew a ballast but that is it and I have used mine at temperatures as low as -48C or about -54F
Old May 15, 2010 | 05:36 AM
RawRam2006's Avatar
RawRam2006
Wow. No problems here. Although this is Texas and it don't get THAT cold here ever. -40? Holy crap, why would ever wanna live in such a cold enviroment? I came from MD too. Don't miss the cold. I'll take my sunny skies n heat any day of the year over that cold nonsense. Lol.
Old May 15, 2010 | 05:38 AM
RawRam2006's Avatar
RawRam2006
Especially considering how fast the HID'S heat up. Once lit, u shouldn't have any problems. I had to run ballast on each h3alight due to the "CANBUS" thing. Not on my fog lights though. They were ok, as they are not controlled by, or monitored by, the "CANBUS" thing.
Old May 15, 2010 | 08:47 AM
oyen24's Avatar
oyen24
I haven't had any problems with mine thus far. I do have a question for you though CPelton. I talked to you when I got my HID kit, and got the same kit you got. Did you do your fog lights? And if so, did you just get the regular kit, or did you have to get the error code elimanators also?
Old May 16, 2010 | 03:27 AM
RawRam2006's Avatar
RawRam2006
I know this question was not for me, but, ur fog lights are not monitored by the computer. No need for the "code eliminates", also known as "capacitors". They are just "plug n' play".
