Fog lights on with high beams 2010
Yep I went outside to the truck and I found the little switch under the headlight ****, it is for the rear cargo bed
You have to push in on the whole headlight dial to turn them on. I also think the lowbeams have to be on for them to actually come on. Little light on the dash will come on when they are on as well
Oh I guess I should have mentioned, to get the fogs to come on with highbeams... It can be done with a starscan if you have a dealership willing to do it or someone with the tool. I also believe either the bullydog or diablo (can't remember which one) has a setting for fogs w/ high beams....
