4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Depends on the technology of your charger. Problem is that you are going from 12VDC to 120VAC back to ?? DC. Some power supplies don't like running off the square wave (Chopped) 120VAC.
You cannot get AC from a square wave. You can get AC from a simulated sign wave and that is what the inverter does. But you are correct that it is a chopped up simulated voltage pattern. Dirty as it gets unless the truck has a rotary converter which I doubt it does.
The reason there is no third ground terminal on the 120 volt receptacle is because you have no earth ground like you do in your house.
Square wave is what you get from cheap invertors (as opposed to a sine wave)
