Service Intervals - WTF?
Old May 17, 2010 | 06:47 PM
ohioram4x4's Avatar
ohioram4x4
Thumbs down Service Intervals - WTF?
Was at dealer today to check on my tranny issue...but I just got pissed and left....that's a whole nother issus!
However, while there, I asked what needed to be done to make sure that my Chyrsler Lifetime Warranty remains in tact. The service advisor said that I had to make sure I stayed current on service. According to her.....the major three are:
Front & Rear Differential fluid change every 15k
Transmission Flush every 30k
Plugs every 30k
15k for differential changes....c'mon! That's ridiculous!
And tranny at 30k ain't that far behind ridiculous!
Or is it just me????????
Old May 17, 2010 | 06:52 PM
oldjeep's Avatar
oldjeep
I don't know what they are looking at. Those are not the maintenance intervals in the manual.
Old May 17, 2010 | 07:07 PM
72combo's Avatar
72combo
I was gonna say the spark plugs are right but the other stuff I would have to look but I don't think so, oh but you have lifetime guarantee so yours might be different, so it is true they want our trucks to puke so we have to spend money on a new one. Maybe we should follow the lifetime maintenance agreement even if we don't have it, seems Dodge does not want us to have our trucks last too long.
Old May 17, 2010 | 07:11 PM
hounddogg's Avatar
hounddogg
It has to have maintance as PER THE OWNERS MANUAL.Thats it.The dealer can and they often do recomend service at other then whats in the book.Its there shop/store.Nothing wrong with that.
Old May 17, 2010 | 07:16 PM
mike2810's Avatar
mike2810
From my 2009 Ram owners manual under Maintenance.
18,000 Miles (30,000 km) or
18 Months Maintenance
Service Schedule
Change the engine oil and engine oil
filter.
Rotate tires.
Inspect the front and rear axle fluid,
change if using your vehicle for police,
taxi, fleet, off-road or frequent trailer
towing.
30,000 Miles (50,000 km) or
30 Months Maintenance
Service Schedule
filter.
Rotate tires.
Replace the engine air cleaner filter.
Replace the top row of spark plugs
(4.7L Engine).
Replace the spark plugs (3.7L and
5.7L Engines).
Inspect the transfer case fluid.
60,000 Miles (100,000 km) or 60 Months Maintenance Service
Schedule
Change the engine oil and engine oil filter.
Rotate tires.
Inspect the brake linings; replace if necessary.
Replace the ignition cables (3.7L Engine).
Replace the top row of spark plugs (4.7L Engine).
Replace the spark plugs (3.7L and 5.7L Engines).
Change the automatic transmission fluid and filter if using your vehicle for any of the
following: police, taxi, fleet, or frequent trailer towing.
Change the transfer case fluid if using your vehicle for any of the following: police, taxi,
Flush and replace the engine coolant at 60 months if not done at 102,000 miles
(170 000 km).
Looks like front/rear diff at 18K
Transfer case and Plugs at 30K
Tranny fluid at 60K
Check your manual. Its near the back.
Old May 17, 2010 | 07:30 PM
crod's Avatar
crod
well , it looks like you HAVE to change those fluids at those times IF you use your vehicle for "hard" use as stated.
police/frequent towing etc.....
and once again. IF is the key word here....
Old May 17, 2010 | 07:39 PM
hounddogg's Avatar
hounddogg
If not towing/police or off roading the differentials are only a fliud level check.The dealer can recommend changing the fliud all they want but all it takes to make warranty requirments is whats in the owners manual.
Old May 17, 2010 | 07:46 PM
CarGuyOhio's Avatar
CarGuyOhio
That service person is not up to speed. 15K was for 3rd Gen Rams. 4th is 30K on the differentials. Sad when people who's job is not to know this stuff turns out to know more than the pros. I would send a letter to the dealer manager/owner and CC Chrysler so it gets his/her attention.
Old May 17, 2010 | 08:01 PM
hounddogg's Avatar
hounddogg
15k is also TOWING/off roading etc. My 03 Dodge dually has AAM axels(American Axel Manufacters) and 15k is for full time towing etc.Otherwise the fliud change is like 100k or such.
Old May 17, 2010 | 08:15 PM
dahemi's Avatar
dahemi
Plugs every 30k
If you want the truck to last, do the required maintance.
They don't require it for the hell of it. They test parts for hundreds of thousands of miles to be able to make them last the longest they possibly can and that is by recomending certain things to be done at certain intervals.
Do them yourself and just document and save everything.
