4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
the esp uses the abs system and detects wheelspin and applies pressure to the brake caliper to limit wheelspin so it should work no different then the factory lsd
well.. i think it would effect it.. if the truck senses both rear wheels spinning and the front wheels not spinning it would activate both rear brakes.. but there again isnt there people on hre with 3.91 or 4.11 gears with the ESP system? they shouold be able to tell you how the ESP is effected. cuz the 3.91 and 4.11 are a LSD
