Locking Tailgate
Old May 28, 2010 | 08:16 AM
bigt204's Avatar
bigt204
Default Locking Tailgate
Im wanting to convert my non locking tailgate on my 09 1500 sport CC and came across the ones that bak industries has, has anyone tried these yet? what other options are available?
Old May 28, 2010 | 08:18 AM
oldjeep's Avatar
oldjeep
Easiest way is to just buy the factory parts. There are several threads here with the part numbers. While you have it all apart you might want to also add the factory power lock so that the tailgate locks and unlocks with the doors.
Here's a good one on installing just the locking handle
https://dodgeforum.com/forum/4th-gen...-walkthru.html
And here is mine on installing the power latch
https://dodgeforum.com/forum/4th-gen...k-install.html
Old May 28, 2010 | 08:59 AM
bigt204's Avatar
bigt204
how much did the automatic lock mechanism set u back?
Old May 28, 2010 | 09:00 AM
oldjeep's Avatar
oldjeep
Right around $100. It does require that you have the locking handle, so you also need to buy that and the rods.
http://www.mopar-accessories.com/en-...=3280&pc=45972
Old May 28, 2010 | 09:13 AM
bigt204's Avatar
bigt204
alright, thanks. not too sure whether ill go with the auto locking setup or not but its an option thats available
Old May 28, 2010 | 09:24 AM
72combo's Avatar
72combo
for 89 bucks you can put the Pace Edwards power lock on, fairly easy hardest part is running the wire under the truck to the front but it is much easier to hook up than the factory one. Only drawback is no power no open tailgate. Unless of course you can get into your tonneau and open that then if you really have to open the tailgate and no way to get a boost or anything you can always open the inside cover of the tailgate and unlock it manually. I have not had an issue with mine Ihooked it up to open with the drivers door, you can set it up to work with the rest of the doors instead..Comes with 2 relays and hooks directly to the battery and and the main ground then 2 wires to the up and down wires of the lock...and your are all set working with your keyfob. No programming. Simple.
Old May 29, 2010 | 09:59 AM
bigt204's Avatar
bigt204
Don't u need the locking tailgate already for the pace Edwards one? I looked in to that and that was the way I understood it. Or does it just prevent the handle from bein opened?
Old May 29, 2010 | 06:35 PM
72combo's Avatar
72combo
Nope it is the power lock and yes it prevents the handle from being lifted.
