First time towing...no problem
Also, the Uhaul trailers have surge brakes, so they connect utilizing the 4 pin connector. One more fyi - there is no way to lock the trailer to your truck.
I'd suggest taking the trailer into a large empty parking lot after you've picked it and practicing backing up. Eventually you'll figure it out (or at least get better at it) and in case you come across a moment where you have to back up on your journey, with a load, you'll be more comfortable.
What is the maxim towing capacity. I read that on this new 09,10 is around 10000 lbs as long as you have the HD package.
