Ipod
Old May 29, 2010 | 07:43 PM
det1t's Avatar
det1t
Default Ipod
I am a little confused and need some help. I bought my first Ipod a month ago and I assumed I could hook it up to my 2010 truck by connecting it to the auxiliary jack but it doesn't work. I went to Best Buy and the guy came out to my truck and hook up his mp3 player to the auxiliary jack port and it worked. What am I missing? He used the same wire that I used to connect my Ipod.
Old May 29, 2010 | 10:05 PM
hemiken's Avatar
hemiken
check the volume on your ipod, on mine if the ipod volume is all the way down you cant hear it so i keep my ipod all the way up and control it with the truck volume. If that is not it i dont know.
Old May 29, 2010 | 10:13 PM
BigBlueEdge's Avatar
BigBlueEdge
Which radio do you have? Does it have the iPod interface and cable in the glove box?
Rob
Old May 29, 2010 | 10:25 PM
HEMISPORT10's Avatar
HEMISPORT10
+1 on the volume
Old May 29, 2010 | 11:04 PM
jhedger's Avatar
jhedger
gotta be the volume.
Old May 30, 2010 | 07:32 AM
det1t's Avatar
det1t
No it does not have the Ipod interface in the glove box.
Old May 30, 2010 | 09:24 AM
BigBlueEdge
Looks like the AUX input is your only option then. Sounds like the other folks have found the likely issue with the volume for making AUX work. If that still doesn't help I guess I'd suspect the connection cable. Maybe it isn't the right style?
Rob
Old May 30, 2010 | 05:31 PM
det1t's Avatar
det1t
Thanks everyone for the help although I couldn't get it to work I just downloaded the songs to my phone and used the same cable. It works now so I am happy but not happy about throwing money out the window on an Ipod.
Old May 30, 2010 | 05:48 PM
hemiken's Avatar
hemiken
Maybe there was something wrong with the ipod, did you try exchanging it for
another one just in case?
Old May 30, 2010 | 07:07 PM
jhedger's Avatar
jhedger
there is absolutly no reason the iPod shouldn't work through the Aux port via your headphone output and the proper cable...check the volume on the iPod, otherwise exchange it.
