Howling noise from Driver's Door at highway speeds
Old Oct 15, 2010 | 08:44 AM
  #21
dakynz's Avatar
dakynz
so finally got my truck back yesterday. And it appears, through several tests that the howling issue is finally gone. It took 3 trips to the dealer but they fixed it
1st trip: diagnosis issue but nothing done
2nd trip: dealer sent truck to the body shop to pull driver side door in. Eliminated some of the noise but still there
3rd trip: replaced driver side door seal. Sound completely gone
The only bad thing is that the door was adjusted and if you shut it lightly it won't shut completely. But, honestly I wouldn't notice it unless I knew that the door had been adjusted. A little firmer push and shuts just fine. Happy that the dealer addressed the issue and everything went smoothly with no debating or $$. A happy customer
Old Mar 22, 2011 | 01:26 AM
  #22
apick35's Avatar
apick35
Question wind noise
i have had my truck for about seven months and the other day my truck made this howling sound from the wind and it only happened during a crosswind, after reading everything posted i looked at the truck. in side the door hinge and could see ,tucked inside the fender behind the door hinge is a foam strip that has a lose fit and i was wondering if that could be the cause?
Old Mar 22, 2011 | 02:26 PM
  #23
zman9788's Avatar
zman9788
Mine was fixed after they replaced the door seals on both front driver and passenger side doors. It howled in any strong crosswind while driving on the highway. If they give you crap about not being able to duplicate sound, be persistent and make them change out the seals. No problems since, so far. To test if it is seals, push out on upper edge of door while driving. If sound changes, it is the door seals. Good luck.
Old Mar 20, 2012 | 11:37 PM
  #24
LU229's Avatar
LU229
Member "DodgeCares" (Chris B) posted this just recently.
NUMBER: 23-024-11
GROUP: Body
DATE: July 12, 2011
SUBJECT:
Whistle And/Or High Pitch Windnoise At Door Near Windshield A-Pillar
OVERVIEW:
This bulletin involves installing a foam stuffer block into door weatherstrip for vehicles on
the VIN list or checking for wind noise at A-pillar for vehicles not on the VIN list and if
necessary installing a foam stuffer block into door weatherstrip.
MODELS:
2009 (DH) Ram 2500
2009 (D1) Ram 3500
2009 - 2010 (DC) Ram 3500 Cab Chassis
2009 - 2011 (DS) Ram 1500
2009 - 2010 (DM) Ram 4500/5500 Cab Chassis
2010 - 2011 (DJ) Ram 2500
2010 - 2011 (D2) Ram 3500
2011 (DD) Ram 3500 Cab Chassis
2011 (DP) Ram 4500/5500 Cab Chassis
NOTE: This bulletin applies to vehicles built before April 18, 2011 (MDH 0418XX).
SYMPTOM/CONDITION:
Customer may experience whistle and/or high pitch windnoise at door near windshield
A-pillar.
__________________
Chris B.
Top Care Specialist
Chrysler Group LLC
Old Mar 21, 2012 | 08:27 PM
  #25
Capn Preshoot's Avatar
Capn Preshoot
Here's a link to the RRT (11-057)
http://reviews.ebay.com/Chrysler-RRT...00000076876009
