Old Aug 17, 2015, 12:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Synthetic Oil
Old Jun 6, 2010 | 12:09 PM
Thack's Avatar
Thack
Originally Posted by 72combo
Does synthetic oil have any detergents in it because I believe you must use an oil that has some type of detergent.
Yes, non detergent oil is hard to find nowadays and will usually be a SAE 30 or so. It is used in air compressors and the hydraulic pump of old tractors.
Old Jun 6, 2010 | 03:40 PM
1500TRX's Avatar
1500TRX
First factory oil changed out at 500 miles, went synthetic blend till 5000 miles, and been using valvoline full synthetic with a Napa branded Wix (7899) filter ever since. Change it every 5000 miles religiously with tire rotations myself.
Old Jun 7, 2010 | 11:51 AM
OneSickHemiRam's Avatar
OneSickHemiRam
Originally Posted by Jeff Dodson
This was my question. I also have a 2010 Harley Davidson and the recommend not untill after 5000 miles, reasoning is for break in period to make sure the rings seat good. Thanks, I will wait till the first changes. BTW, I run Royal Purple in my bike, but will run Mobile 1 in the truck. Price reasons
DUDE! Drop the Royal purple ASAP! That stuff is all BS. So many other real synthetics out there. I run Motul in my K7 GSXR 1000 and I beat the **** out of that bike.
Old Jun 27, 2010 | 10:32 AM
it's all dodge's Avatar
it's all dodge
Changed mine at 2800, no light on, but knowing it will either come on and need changed when I'm not around, or it would not come on and be in the engine for well over a year. Put in the reg stuff, but oil change #2 will be Valvoline Syn. Seems like it takes over 7 qts to get to right at the full mark on the dipstick. Glad to see the same filter wrench I used on my Dakota works on the Ram!
Old Jul 5, 2010 | 11:28 PM
DroopyDog's Avatar
DroopyDog
Just curious. Anyone using Valvoline SynPower 5 W 20? Good/Bad?
Old Jul 6, 2010 | 07:30 AM
hounddogg's Avatar
hounddogg
Wait for the OLM to tell you when.Let it break in some.You could run synthetic any time.
Old Jul 6, 2010 | 07:45 AM
HammerZ71's Avatar
HammerZ71
Break-in today is not what break-in was 20 years ago. Your engine is basically "broken in" at about 500 miles and it would be fine to change your oil any time thereafter...
Old Nov 28, 2011 | 01:08 AM
LU229's Avatar
LU229
Dammmmmmmmmm GOOD...!!!!!!!!! The BEST as far as i`m concerned...!
