4" Suspension Lift with 33" tires?
Old Jun 24, 2010 | 02:22 PM
thirdjeep97tj's Avatar
thirdjeep97tj
Default 4" Suspension Lift with 33" tires?
I want to lift my 09 1500 Crew Cab 4x4 but don't really want to go bigger than 33" tires. I only need about 2" of lift, but would prefer getting the advantages of a true all out suspension lift and not spacers or just a leveling kit. My concern is that Mopar/Superlift 4" of lift and only 33" tires will look bad. Anybody got a pick of this setup or close? I know 35"'s look good, but I just don't want another vehicle on 35"'s. Thanks.
Old Jun 24, 2010 | 03:00 PM
Thatmarkguy's Avatar
Thatmarkguy
The factory 20" wheel and tire set-up is already 33". You don't need to lift your truck unless you are going wide and need it for clearance.
Old Jun 24, 2010 | 07:29 PM
mrainv23's Avatar
mrainv23
When my lift was installed I had to send a custom wheel back and I put my factory 20s on for a week and it looked weird. The stock 20s are 32 inches. If you do 33s just level. My opinion.
Old Jun 24, 2010 | 10:23 PM
Doc Fluty's Avatar
Doc Fluty
my laramie had 275/60/20 tires stock = 838mm = exactly 33"
