4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Amsoil says that the additive MIGHT be needed. Had customers use Amsoil and others that it turned out it was always needed.They ended up with judder on turns.Try it without and see.All it takes is pouring a bottle in if the differential shudders.
If the bottle of gear oil doesn't say that the friction modifier is included, and your vehicle requires friction modifier (i.e. for a limited slip axle) then ADD IT. This is not complicated.
