Coil spring air bags?
The Firestone Coil-Rite instructions don't mention removing the spring. It says you can remove the shock to allow the spring to extend apart further, if needed. Otherwise you seem to just slip the bag through the coils.
http://www.firestoneindustrial.com/p...ation/4185.pdf
Rob
Rob
Now about height. Since the two companies bags are two totally different heights, it does seem to me that the bags don't actually work as a top/bottom bag as most do. My understanding of them is that when inflated, they bulge between the coils and give the 'lift' from the coils not being able to compress as easily, not from holding up the truck itself like a leaf spring bag does. Now, I would assume that a taller bag would hit more coils vs a shorter bag, thereby allowing less sag. BUT, the shorter bags are much thicker then the taller ones, which probably allows less movement of the coils touched. In the end, I think it is a wash.....
As for the guy who said he built spacers, I just wonder if that will affect the bags since stock, they don't reach top to bottom?
I have a 31 ft travel trailer with a 650lb tongue weight and even with a weight distributing hitch the rear sags quite a bit and I get some back to front rocking while traveling down the road. Has anyone installed the new Firestone Coil Rite air bags for xtra support? If so, did you do it yourself, how long for installation and are you happy with the results? I ordered the bags today and am hoping they take care of my problems. Another question. Since the dealer set up the Blue Ox hitch without the bags am I going to have to reconfigure the setup once the bags are on? Thanks in advance for any imput.
Right now I am running around 13 PSI and around the neighborhood it feels fine - too early to tell.
About the weight distribution bars, If the ride height of the *** end changes too much, then that alters the weight distribution to the front end. It's all about the angle of the pre-load and final angle of the ride when fully loaded.
Just put the Ride-Rites on and take a trip and carry your tools so that if need be, you can adjust the bars.
I will be taking my first trip next week towing my trailer with the Ride-Rites and will report then. My last trip without the bags was OK but I was working really hard at the loading of weight on the bed closer to the cab. The more weight you put on the bed the more you need the bags.
Yeah, here are the instructions:
VEHICLE PREPARATION
With the vehicle on a solid level surface chock the
wheels and raise the vehicle using a jack rated for your
vehicle weight to lift the wheels off the surface. Remove
the wheels. Lower the vehicle frame onto jack stands
rated for your vehicles weight making sure the suspension
is fully extended. (Do NOT use wood or concrete blocks
to support the weight of the vehicle.)
I had to make a spacer because the mopar/super lift coils sit 2.5" taller than stock so the bag would not fill the space. Same idea as the airlift, it is a shorter bag than firestone so it comes with a 2.5" spacer to take up the slack. I called firestone and with the truck unloaded they should just fill the coil top to bottom.
Ive got 10 psi in mine and i cant tell. I fill them to 30 with trailer on.
