IPod
Old Jul 16, 2010 | 11:28 PM
moperkont's Avatar
moperkont
Default IPod
Hey all,
I just bought an 2010 Ram Sport and it has the Ipod connect cable and the dvd deck. However if I hook up my Ipod classic it wont pop up as an option on my deck. Does it not support the older Ipods? or do I maybe have a problem?
Thanks
And also, Ive done a search for watching dvds while driving....is there any nice way around this?
Old Jul 16, 2010 | 11:57 PM
72combo's Avatar
72combo
You might have the newer cable. Not sure when but Ipod changed from 12V to 5V and the cable changed also. I don't know the number nor what type of connection you have now.
Old Jul 17, 2010 | 01:12 AM
moperkont's Avatar
moperkont
ok. thanks. ill try a new ipod to see if that fixes it. if it does i know I need the other cable. or else ill buy a new ipod since my old one has a cracked screen anyways.
thanks again
Old Jul 17, 2010 | 09:04 AM
72combo's Avatar
72combo
you can get an adapter for the end of your cord
Old Jul 17, 2010 | 10:15 AM
BigBlueEdge's Avatar
BigBlueEdge
The cable issue is really just about supporting device charging. Either cable should still allow iPod integration with the radio. Seems like something else is wrong.
You are talking about the 'iPod connect cable' located in the top glove box, right? Not the 1/8" mini-plug 'Aux' input cable? Though the 'Aux' input should work too, you'd have to control play on the iPod manually with that one. The big cable in the glove box allows you to actually fully control the iPod from the radio.
In order to play DVDs while moving you have to buy a 3rd-party device to 'hack' the system. Two I've heard of a AllGig and LockPick. Searches for those names will get you all the info on them you could need.
Rob
Old Jul 18, 2010 | 01:47 PM
moperkont's Avatar
moperkont
I am talking about the cable in the glove box. I have tried my Ipod Classic and an Ipod Touch to see if that was the problem and still no luck. If I plug it into the Aux plug then it works but I would like to control the Ipod with the deck. Maybe Ill track down to the dealer and see if they can check it out.
As for the DVD, i stumbled upon those setups to bypass. I also found that you can download the older software and bypass it by putting the movie in, then switching to the audio equalizer, put it in drive and then hit view video and it will work. We shall see. Its obviously not for me to watch when I drive, but its nice for the passengers.
Thanks for the help. Ill let you guys know what the deal ends up being with the Ipod.
Old Jul 18, 2010 | 04:37 PM
BigBlueEdge
Sounds like there is a problem with the radio or cable. No reason the iPod Touch shouldn't work (playing music at least, not necessarily charging).
What is the deal with downloading 'older software' for the DVD viewing?
Rob
Old Jul 18, 2010 | 08:44 PM
moperkont's Avatar
moperkont
Unable to find the link I had again. But found some other info that says a downgrade effects sound quality.
If I figure anything out I will post it here.
Old Jul 18, 2010 | 08:56 PM
moperkont's Avatar
moperkont
dont know if my ipod is causing problems cause I have a RBZ radio...most info I find is about REN or RER radios....
