2010 Ram 1500 OEM Trailer Brake Controller Install
Old Feb 18, 2012 | 02:04 PM
White2500's Avatar
White2500
I used just any small screws I had around! Even the thread was different but I force the screws in, they made their own thread on way in and are secure tight.. No problems at all
Old Feb 26, 2012 | 11:13 AM
2011BlackRam's Avatar
2011BlackRam
Originally Posted by rdculus
Where did you get the screws to secure the controller to the bezel?
It looks like there should be 2 screws to hold it together, one on the top of the controller and one on the side.
What size screws did u use, it seems like the t-20 torx screws used on everything else are too big.
thanks
Honestly, I'm not sure what size screw they were. I took one of the factory ones that held the trim piece in with me to my local Ace hardware, and they had a whole section for the black philips head automotive screws. I bought a couple different lengths that were the correct diameter.
Edit: I ended up using the shortest ones I could that still held everything together.
Old Feb 29, 2012 | 04:57 AM
rangstng's Avatar
rangstng
Will that be the correct part# for a 2012 as well?
Originally Posted by erluisi
Thanks for the pictures and write up. It took me about a half hour also, but couldn't have done it that fast with out your thread and pictures. I purchased the trailer brake and bezel from "DCJ Parts" (dealership in NY) on line for $118 including shipping. Terrific deal if you buy the two pieces separately. The kit runs $225 to $300, but it does come with 3 screws - Wow. I ordered part # 56029431AH-OEM Brake control unit and part # 1EB13XDVAA - Dark gray bezel. Tan bezel is part #1B12DK2AA a just FYI.
Old Mar 7, 2012 | 08:25 AM
MattsMountain's Avatar
MattsMountain
Does anyone know if this will work on a 2009 ... with the tow package?
