After market wheel offset?
Old Aug 13, 2010 | 04:37 AM
BigHorn 4 Life's Avatar
BigHorn 4 Life
Originally Posted by oyen24
Hey big horn 4 life. Do you happen to have pics of your truck with those rims and tires on. I am looking at a set of rims that are 20 by 10 and have a -25 offset. Just wondering if that will work on my truck with a leveling kit?
Sure do,
This pic was before my 2" spacer and my finderflares.
Old Aug 13, 2010 | 08:05 AM
oyen24's Avatar
oyen24
Hey thanks big ram your truck looks awesome. So if I go with the 20by10 -25 offset, do you think I would need wheel spacers? Also, do you have any rubbing at all? I don't want to spend the money on something like the rims and tires and not have them work.
Old Aug 14, 2010 | 04:33 AM
BigHorn 4 Life
Thanks .No rubbing here.I have an 8" lift.
If your not lifting your truck then I would not go with a negative offset.It will push your tires outside of your finders and that will cause them to rub.
Old Aug 14, 2010 | 01:25 PM
oyen24's Avatar
oyen24
I did put a leveling kit in my truck, so it is lifted 2" or so. Do you think that is enough or should I still not even mess with a negative offset. The problem is, is that i found a set of Dale Earnhart JR rims that only come in a 20 by 10 with -25 offset. And I would like to run a set of 305/50/20s on them. Maybe by the time I get the money for the rims, they will make that set I want to better fit my truck.
Old Aug 15, 2010 | 08:07 AM
BigHorn 4 Life
33's shouldn't rub.You should be ok with that settup.
