4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just a heads up though: While doing what BigTex advises will help out your sound, it does void your warranty as well. Ran into this when I wanted to do True Dual exhaust.
This will not void your warranty. If a dealer is telling you this, then they are either blowing smoke or they dont know what the hell they are talking about. the only point that will void your warranty is if you mess with the CATS, which are way up front anyway. what i did in no way messed up the warranty. you will be fine!
the only part of the warranty it shold void is the muffler shouldn't affect anything else, has anyone ever replaced just the muffler and left the resinators and if so how does it sound
The dealer also told me that if you start messing with headers and cats, then you will likely have a warranty issue. I should have included that. Since Mopar offers a cat back for these trucks, it shouldn't be any different if you put you own system on.
i just got my truck two days ago mine came with the factor duals, i'm assuming its the same cat back as they are selling not really sure, mine sounds good, not loud enough for me though
go to youtube and search for mufflex or magnaflow. Mufflex makes a direct bolt in muffler replacement. I have the 18". here is my youtube site with a before and after http://www.youtube.com/joshjac1
I'm pretty sure Mopar is using the Corsa cat-back and putting the Mopar name on the tips. Look under Corsa cat-back on You-tube. There is a clip of a Corsa system on a 4th gen, which would be the same as the Mopar.
