Diff fluid change and Gear oil from the dealer
Just a word of advice for those of you who are going to change your diff oil. I went to my normal auto parts store looking for the 75W 140 synthetic that the ram requires and they didn't have that particular type. So I figured I'd go to the dealer and just get it there, since I was picking up a set of plugs too.
Guy at the parts counter says are you sure you want this stuff, its pretty expensive. $30 a quart for the mopar stuff. He suggested I go over to Napa instead. I don't normally buy anything at Napa, but they did have it (Valvoline Syn Power) and $13 a quart was a heck of a lot better price.
The permatex like stuff that they use on the diff cover from the factory is kind of odd. It's some sort of non hardening sealer - removes easily with a dry scrubby sponge. Took about an hour and saved almost $100 off what the dealer wanted to charge.
Mobil One makes full synthetic 75W140. You can get that under $15 at many auto parts places and maybe even Wal-Mart.
Mopar is odd on their pricing for lubricants. For some standard things, like this 75W140 gear oil, they are way too expensive. But I needed NV245/249 specific lube for the transfer case on my Grand Cherokee and only the dealer sells it so I went to buy it there... it was something like $13/quart. I was floored that it wasn't $30/qt.
Rob
Rob
I've got just over 30K on the truck right now. Dealer mentioned that my diff fluid should be changed when I had it in at around 26K. The gear oil was fairly dirty looking when I changed it today.
Rear diff just uses a permatex like substance, I used Ultra Black when I resealed mine. I assume the front is the same (I've got a 2wd). Tcase is ususally just a drain and fill plug but not 100% sure since I don't have one.
Yeah I don't tow, go off road, drive on dirt roads etc. But I'll prob swap em out at about 24k-30k just because. I want to keep this truck for a LNG time
