Powergate Tailgate Lock and Backup Camera
Hello All,
I'm about to order the Powergate Tailgate Lock LK170 and I was wondering if anyone has installed an aftermarket keyhole camera in the handle on the opposite side of the tailgate lock assembly. Looking at the taigate, it appers that you could install a camera on the right hand side of the lock. I was going to use a dremmel tool to make the cutout and mount a surface mount keyhole camera.
If anyone has any suggestions on cameras they have installed, any info would be appreciated. Some cameras seem so cheap that it must be too good to be true... Others just don't have much information at all on thier websites.
Any help would be much appreciated.
which camera did you buy? most cameras don't give any dimensionsand i'd like to get one that has decent picture quality as well.
I purchased my nav unit and they included the rear view camera. The site, if I remember correctly is www.oemautopartsco.com
Hello All,
Wow 72!!! That looks awesome!!! Where did you get your camera's? Which model did you buy?
Also, can you see your bumper on the screen with that camera setup?
Thanks
Thanks
Trending Topics
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_3287wt_1018 I think the wiring was a bit on the cheap side so I upgraded a bit...not necessary but I am a goof. I might not even use the new wiring just put it all in protection. I need to drill at least half inch hole in the firewall somewhere on drivers side since it will be double the wiring since I am putting a cam out front too. I have had the lockpick and cameras for since like May or maybe sooner LOL. The plan is to have it in by the end of the long weekend but I won't hold my breath.
That's the hardest part, I ran mine inside the tailgate through the access hole. From there the wires split, one set gets attached to your reverse lights and the other set gets ran on the drivers side frame rail into the engine bay through a gromet on the drivers side fire wall and into your cabin. Bring lots of zip ties and some weatherstrip adhesive to repair the larger gromet opening..
Mine all get attached to my lockpick and the back of the radio. I think I will stick with running it all under in wire loom along the trailer wiring.I have to see if I can fit the power lock wiring in with it or just leave it alone how it is now. Was supposed to work on it today but we spent the day looking for and then finally bailing our dam dog out of the pound. She took off last night. Home sweet home 110 bucks later.
