Last edit by: IB Advertising
Browse all: Interior Guides
- Dodge Ram 2009-Present: Remote Start Problems
Important information to help you understand your Ram.
Problem with remote starter.
Oky Dok. I had time at lunch to go check it out. Yes the EVIC told me that the hood was ajar. But it wasn't. So Looked around and found that switch is located in a little cup near the radiator support. So I held it down and the remote started functioned properly. I let go and the engine shuts off. So I close the hood real slow and see that there is no way that the hood could push down on that button. Can someone look and see if there is a little rubber bumper or something on the hood that pushes that button down. Looks like there is a hole in the hood that they might stick in a little rubber piece, but it is missing on my truck. This was before I read these replys, so I might have to put something on the switch like mentioned by dakota_raven. So thanks for that. I guess it pays to look at the EVIC. But I was not in the cab when I tried it. So problem solved....sorta.
