2009 Rough Idle and vibration HELP!!!
Old Sep 8, 2010 | 10:37 AM
Chris Scata's Avatar
Chris Scata
Default 2009 Rough Idle and vibration HELP!!!
I have a 2009 Sport 5.7 Hemi at around 20K miles it started witha rough idel, like it was missing. I have taken it dealers numerous times & they can feel the rough idle but when they hook it to the diagnostic machine it doesn't give them any "codes" so they say nothing is wrong. I drive the truck every day since I bought it brand new & something IS wrong & is getting worse & worse. I have changed spark plug air filters, oil changes & nothing seems to help even for a short time.
Old Sep 9, 2010 | 06:46 AM
oldpianos's Avatar
oldpianos
So sad that if the computer doesn't show a problem, then it's fine. Are there any real mechanics anymore? Just computer technicians with a wrench?
Old Sep 9, 2010 | 09:46 AM
05Dakotaho's Avatar
05Dakotaho
See if you can get an inexpensive compression check. My dealer charged about $125 for the check and discovered one bad cylinder on each bank. Did a double valve job under warranty and that corrected the rough idle.
Old Sep 11, 2010 | 09:32 PM
Arvada's Avatar
Arvada
Also some injector cleaner might help.
