PCV valve location
Old Oct 3, 2010 | 02:53 AM
renos09's Avatar
renos09
Default PCV valve location
Can anybody tell me where the PCV valve is located? A photo would be even better, Thanks.
Old Oct 3, 2010 | 10:06 PM
Mark Benson's Avatar
Mark Benson
REMOVAL
The PCV valve is mounted into the top of the intake manifold. This is located to the right / rear of the throttle body (2).
1. The PCV valve is sealed to the intake manifold with 2 O-rings (2).
2. Remove PCV valve by rotating counter-clockwise 90 degrees until locating tabs have been freed. After tabs have cleared, pull valve straight up from intake manifold.
3. After valve is removed, check condition of 2 valve O-rings.
Old Oct 4, 2010 | 12:34 PM
graverobber09's Avatar
graverobber09
Look at you passenger maifold, you'll see a hose that runs from the back of the valve cover to the bottom of the throttle body(where the intake tube connects).
Its not the hose that connects to the intake tube
Old Oct 5, 2010 | 12:41 AM
renos09's Avatar
renos09
ok, thanks
Old Nov 14, 2019 | 09:04 PM
Joel Figueroa's Avatar
Joel Figueroa
I know the reply has taken awhile, however, label 1 has a hose attached. Follow it and you’ll see it go under the EGR, unplug the hose from the PCV that’s underneath the EGR. Use a 24 mm deep socket to remove the PCV valve. Installing it is the reverse.
Old Nov 14, 2019 | 09:16 PM
Taken a while? Yeah, that's putting it mildly. Nine years? I would most certainly hope this was solved a LONG time ago.
