Dealership Cost
Old Oct 6, 2010 | 05:40 PM
mpullen32's Avatar
mpullen32
Default Dealership Cost
Took the truck to the dealer today and they mentioned that I need to change my differential fluid (front, rear, transfer case) as well as my brake fluid. They quoted me a price 358.00 for the diffs and 140 for the brake fluid flush. How hard are these to change yourself and will it void a warranty if I do it myself?
Old Oct 6, 2010 | 07:25 PM
USAF1's Avatar
USAF1
What model truck do you have and what year and how many miles on it?
Oleksakjr's Avatar
Oleksakjr
Its considered normal maintenance, they CAN NOT void your warranty for completing maintenance. However, dont screw it up...
Old Oct 6, 2010 | 07:27 PM
USAF1's Avatar
USAF1
You will need receipts to prove what you did. And like Oleksakjr said, don't screw it up or they can void the warranty but only on this that you directly affected with bad maintenance. Use the correct recommended fluids, etc.
Old Oct 6, 2010 | 07:33 PM
Oleksakjr's Avatar
Oleksakjr
^^^ Exactly, they arent hard to do yourself, but if its your first time, just take your time. Youd definitely save a bunch, and good luck
Old Oct 6, 2010 | 07:42 PM
oldjeep's Avatar
oldjeep
Brake fluid flush? You have a couple hundred thousand miles on the truck?
Old Oct 6, 2010 | 07:53 PM
Attono's Avatar
Attono
Why do you think you need the receipts? I've never had a dealer ask for recipts or records of maintenance in order to do warranty work.
Old Oct 6, 2010 | 08:12 PM
mpullen32's Avatar
mpullen32
Sorry guys the truck is a 2009 1500 with 36,000 miles on it.
Old Oct 6, 2010 | 08:30 PM
05Dakotaho's Avatar
05Dakotaho
There is a growing trend by both dealers and service contract companies to require proof of scheduled services. Also, some states allow this practice and some do not.
Old Oct 6, 2010 | 08:36 PM
05Dakotaho's Avatar
05Dakotaho
Brake fluid change is not a required scheduled service item in my owners manual. Some people think its a good idea but I've never done it and never had contamination or corrosion issues.
