Oil sensor or just mileage meter?
Old Oct 12, 2010 | 01:38 AM
Bobba Booey's Avatar
Bobba Booey
Originally Posted by Bigbody
should i wait for the truck to tell me to change the oil or should i just change it at 3000 miles? i'm at about 2100 right now and wondering if i need to schedual a appointment
You can change the oil at 3,000 miles, but it's just a waste of money and oil. Conventional oils can go approximately 6,000 miles and synthetics can be extended even further. Changing every 3,000 miles is old school and out-dated, but you have the right to change it that often if you like.
FYI, the owner's manual recommends changing every 6,000 miles.
Old Oct 12, 2010 | 07:00 PM
capsfloyd's Avatar
capsfloyd
Cool oil
[quote=Daves Dodge;2288415]My oil change due message just popped up and I only have 2800 miles on my truck, is that normal.
If it is your 1st oil change no, mine was like that on the 1st oil change
Old Oct 13, 2010 | 02:18 AM
CHILLYPOND's Avatar
CHILLYPOND
Originally Posted by itaintachev
My oil msg came on around 5700 miles. Is this just a mileage counter or is there an actual oil testing system in the 2010? My cars have this but it comes on by default every 5K and you have to reset it..
Check this out:
http://www.moparmagazine.com/2009/ma...ing_light.html
Old Oct 13, 2010 | 07:05 AM
hounddogg's Avatar
hounddogg
Good read.Some makes up to 10,000 miles now is acceptable.
Old Oct 13, 2010 | 08:23 PM
silvercorvette's Avatar
silvercorvette
Originally Posted by CHILLYPOND
Thanks for the link. I had the oil changed by the dealer and the light came on about 20 to 30 miles after the change. I brought it back to the dealer and they could not get the light to go out, I tried pressing the diesel pedal 3 times but the light stayed on after many tries to turn it off. I went to the link and the key word is pump the pedal SLOWLY
Old Oct 14, 2010 | 04:21 PM
iimorgans's Avatar
iimorgans
Default Oil Change Light
It uses and Algorithm based on driving conditions..
Old Oct 14, 2010 | 06:31 PM
mike2810's Avatar
mike2810
all depends on the type of driving you do. In my case living in a small town many trips are very short (less than 3 miles), less than 600 miles/month. Oil can start to look pretty dark in 3k.
Basically I do 2 oil changes a year. (6 months of 3K, whichever comes first). If I was doing a long trip then I would agree with you on a 6K change.
Old Oct 14, 2010 | 08:49 PM
05Dakotaho's Avatar
05Dakotaho
Originally Posted by Doc Fluty
i use mobil 1 since the day i got the truck.. and the oil message usually comes on about 6000 miles or so.. last time i drove across country i forgot to tell the guy to put synthetic in and while driving back across country the change oil light came on at about 3500 miles... so it knows something... and doesn't just go by mileage
According to Chrysler's "MOPAR MAGAZINE"
There are six inputs used by the PCM. The factors which indicate severe use (and a shorter oil change interval) for each of these inputs are listed below:
  • Ambient temperature – extended periods of low temperature operation
  • Average vehicle speed – stop and go driving
  • Engine run time – prolonged idling
  • Trip length and coolant temperatures – short trips
  • Engine speed and load – trailer tow usage
  • Flex-fuel percentage – ethanol percentage of more than 60%
No mention of oil viscosity or blend above...Could Flex Fuel or ambient temp have been the cause?
