Oil sensor or just mileage meter?
Old Oct 9, 2010 | 11:11 AM
RA11325's Avatar
RA11325
Default Oil sensor or just mileage meter?
My oil msg came on around 5700 miles. Is this just a mileage counter or is there an actual oil testing system in the 2010? My cars have this but it comes on by default every 5K and you have to reset it..
Old Oct 9, 2010 | 11:18 AM
CarGuyOhio's Avatar
CarGuyOhio
Not a sensor, not miles. Driving habbits and temp (I think) are used to calc when to change
Old Oct 9, 2010 | 11:21 AM
CarGuyOhio's Avatar
CarGuyOhio
Oh and reset by putting ignition on (not running) and depress the gas pedal to the floor 3 times within 10 seconds
Old Oct 9, 2010 | 12:01 PM
John Valdes's Avatar
John Valdes
I would think it is a viscosity sensor?
Old Oct 9, 2010 | 05:51 PM
Bigbody's Avatar
Bigbody
should i wait for the truck to tell me to change the oil or should i just change it at 3000 miles? i'm at about 2100 right now and wondering if i need to schedual a appointment
Old Oct 9, 2010 | 07:37 PM
1970Duster440's Avatar
1970Duster440
Not only engine temp it also calculates ambient temp. thats why when my temp sensor was bad due to the weeping (said it was 105 almost all the time) that it told me to change my oil at 2000 miles. After the sensor and wiring was replaced the next one was about 5200 miles.
Old Oct 10, 2010 | 01:11 PM
Daves Dodge's Avatar
Daves Dodge
My oil change due message just popped up and I only have 2800 miles on my truck, is that normal? Seems way too early to me. What kind of oil are you guys using and what does dodge recommend? Thanks for the help.
Old Oct 10, 2010 | 01:54 PM
CarGuyOhio's Avatar
CarGuyOhio
Hemi? 5W-20.
I have said this before. The truck can not give us an accurate MPG and you want to trust it to tell you when to change oil? Set a schdule and stick to it. The owners manual is a good source of info for this.
Old Oct 10, 2010 | 07:52 PM
deke6520's Avatar
deke6520
Hemi? 5W-20.
I agree. I have mine changed every 5000km or 3 months whether or not the light comes on. Better to be safe.
Old Oct 11, 2010 | 01:05 PM
Doc Fluty's Avatar
Doc Fluty
i use mobil 1 since the day i got the truck.. and the oil message usually comes on about 6000 miles or so.. last time i drove across country i forgot to tell the guy to put synthetic in and while driving back across country the change oil light came on at about 3500 miles... so it knows something... and doesn't just go by mileage
