Pulling new wires from the door to under the dash
Old Oct 15, 2010 | 12:33 PM
Ganthiel's Avatar
Ganthiel
Default Pulling new wires from the door to under the dash
I recently bought a 2010 RAM without power locks. I picked up a kit on eBay and have been installing them. I finally got the solenoid mounted inside the door so it'll reliably lock and unlock the door, and now I need to run wires from it to the control box which will probably be mounted under the dash behind the glove box.
I've got the wire harness and boot removed, so I can see where the wires go into the body near the door. What's the best way to get wires from there to the behind-the-glove-box area? I haven't been able to find a path.
Old Oct 15, 2010 | 02:15 PM
72combo's Avatar
72combo
up the a pillars, across under the headliner and back down the other side? That is the way they say to put the mic for aftermarket mopar microphones more or less and the box for the uconnect mounts to the right side kickpanel up beside the glove box.. It is basically the size of speaker wire correct? Or if you don't want to do all that work run it along the top of the carpet line so it won't get worn by feet.You can just tape it to the floor or wire tie it to the top of the carpet. Just think outside of the truckbox cuz that would just be silly.
