4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Has anyone experienced reduced airflow from the dash vents after having this Customer Satisfaction notice completed? Just had mine done and now it seems like I have more fan noise and less air.
I just noticed that when I switch selector to floor majority of air goes to windshield, very little if any to floor and vehicle was in for hvac recall
If you want to reset your computer pull the positive cable and hold it on the negative post or any other ground for 30 seconds. Don't worry there won't be any sparks or anything then reconnect. I don't know if this will solve your problem but that is how I do a reset on mine.
BE CAREFUL! There is a TSB that says if you have the 6.5" screen radio to disco the radio fuse BEFORE disconnecing your battery or damage can happen to your radio.
