Weather stripping turning white
Old Oct 17, 2010 | 02:11 PM
JYD's Avatar
JYD
Originally Posted by Medic1
I found a product called "Protectant 303". Its promoted as "SPF 40 sunscreen....for your stuff". I bought it as a protectant for my soft tonneau cover, but its for uses on all exterior plastic and rubber etc. as a protectant. I have been applying it about 3 times a year and my trim looks the same as when I drove it off the lot. Not sure how widespread its availability is, but its the best stuff I have found for this application.
You can order a free sample kit here 303 Products
303 is the most amazing stuff in the ENTIRE world. I use it on everything plastic or rubber. It's great for tires and interior detail because it does not contain silicone and prevents fading in the sun (especially to help prevent tires from browning).
It's available at www.autogeek.net or at any marine supply stores. BEST STUFF EVER
Old Oct 17, 2010 | 02:20 PM
Mikes87GN's Avatar
Mikes87GN
Originally Posted by hpc3
Just about every car/manufacturer will do this given enough time. I use "The Wax Shop" light liquid carnuba on my cars/trucks when the trim starts discoloring(maybe annually) and have never had an issue. FWIW this is my 2nd Dodge truck, both live outside year round, and I have yet to see any discoloration in 2yrs. I live in SC if weather/climate matter.
Discoloring yes like fading to a brown tint, but not white like he is reffering. That is rubber that hasn't chemicly cross linked. Or of you do see if turn white years down the road thats oxidation. Which protectants and cleaners can resolve. Rubber will continue to cure throughout its life. So if in fact it is an undercured piece of rubber it should improve all by itself given enough time. And tust me undercured seals is a common thing in todays vehicles.
Old Oct 18, 2010 | 08:50 AM
hpc3's Avatar
hpc3
Default Ah, good to know.
Thanks for the info.
Old Oct 18, 2010 | 10:19 PM
2daks's Avatar
2daks
Great now where getting flooded with cheap rubber.
Old Oct 25, 2010 | 12:16 AM
rrdstarr's Avatar
rrdstarr
I have had the problem on other vehicles and found it to be wax residue. Cleaned it good and applied Mother's Back to Black. Took care of the problem till I slopped wax on it again....
Old Oct 25, 2010 | 01:00 AM
72combo's Avatar
72combo
I made a mistake and been using Meguires car wash soap with wax and now the antenna is turning white...the black plastic part.
