DIY rear axle service
Old Oct 29, 2010 | 06:27 PM
05Dakotaho's Avatar
05Dakotaho
Originally Posted by 72combo
Some quick lube places do it that way but I wonder do they get that dirt that is on the bottom when it done running out?
Shouldn't be no dirt...maybe metal particles. A good magnet might do the trick.
Old Oct 29, 2010 | 06:37 PM
oldjeep's Avatar
oldjeep
Originally Posted by stlram
Why are you guys changing this so frequently? Under normal driving conditions this shouldnt have to be done for 100000 miles.
Depends on your driving. Mine looked awfull at around 24K
I take the covers off, good to be able to see if there is any sludge and inspect the gears for play. Get yourself a small cup brush for your cordless drill - makes cleaning off the rtv quick and painless.
Old Oct 29, 2010 | 07:46 PM
Pedro Dog's Avatar
Pedro Dog
Default LSD - good idea to change the axle fluid at 15K
On my old GMC, if you had the LSD, the axle fluid had to be changed at 15K miles. The plates do wear some and crud gets in the fluid.
Another clarification, the additive is a "friction modifier" that adds more slip to allow the LSD to slip as needed. Most synthetics now days come premixed for LSDs. After changing the fluid, go to a big parking lots and do tight figure eights to get the new fluid on all of the slip surfaces
Old Oct 31, 2010 | 08:59 AM
rolltidehemi's Avatar
rolltidehemi
Thanks for the suggestions.
