1st engine light
today is wed. they found 1 spark plug in # 7 cyl. that was fouled . I run platiums and this is the only one out of 16.
Will pick up the truck today and replace the plug on friday.
Se what happens next.?
First, you changed the plugs 15,000 miles to late, and you used an after market plug. I am surprised they did it under warranty.
The manual specifically says 30,000 miles and copper plugs. Just for warranty sake, I will let them do the plugs in two years. I might be at 30,000 by then, maybe.
The 5.7 Hemi also uses a NGK Platinum.It is used in the Durango hybrid and one other Chrysler product. The part number will soon hit the part counters for 09/2010 trucks as well.As hot as these ignition systems are I find it hard to believe a plug fouled.The thread that I read on another forum that truck went in 3 times in two different dealers.3 times plug was fouled and replaced.Finally a tech got smart and realized it wasn't a plug issue but a coil pack or coil pack connector issue I forget which but that is what fixed it finally.Yours may be a plug issue but I'm skeptical.
Dodge came out with a addemdum on the 30,000 ... I can't recall what the mileage is now . I ck them at 30,000 and they look fine .
Our shop mech. help me replace the 2 plugs , cleared the comp. nd the light is off .
Will see what happens next ?
