Counterbalance/Torsion Bar
Old Nov 7, 2010 | 09:07 PM
Jack772's Avatar
Jack772
Default Counterbalance/Torsion Bar
The salesman that sold me my '09 1500 said the tailgate had a counterbalance that made it lighter to open and close easier.
I think he meant to say torsion bar.
Anyway how do you adjust the torsion bar?
Jack
Old Nov 7, 2010 | 10:49 PM
oldjeep's Avatar
oldjeep
You don't. Its fixed position
Old Nov 9, 2010 | 02:38 AM
kxwhite's Avatar
kxwhite
there is a shock you can add to the tailgate so it will slow open on its own. prevents the tailgate to slam down.
Old Nov 9, 2010 | 08:39 AM
HammerZ71's Avatar
HammerZ71
http://www.stylintrucks.com/parts.as...tfamilyid=2018
Old Nov 9, 2010 | 10:35 AM
iimorgans's Avatar
iimorgans
Jack
Your salesman was right there is a weight at the bottom of the tailgate, there is no torsion bar..
Old Nov 9, 2010 | 10:38 AM
05Dakotaho's Avatar
05Dakotaho
Can you post a pic of that weight?
Old Nov 9, 2010 | 01:35 PM
AZdave's Avatar
AZdave
How would a weight inside the tailgate "counter" the tailgate weight? It would simply add to it.
New tailgate lift assist makes it easier to load and unload cargo. It lowers the effort required to both lower and raise the tailgate, thanks to a tension-releasing torsion bar inside. It's another way the All-New Dodge Ram Heavy Duty helps you carry the load. http://www.dodge.com/en/2010/ram_250...es/boxes_cabs/
Last edited by AZdave; Nov 9, 2010 at 01:38 PM. Reason: change font color to stand-out.
Old Nov 9, 2010 | 05:56 PM
oldjeep's Avatar
oldjeep
There is a twisting spring in the hinge of the tailgate. If you remove the tailgate you will see how the spring assist works.
Old Nov 9, 2010 | 07:42 PM
05Dakotaho's Avatar
05Dakotaho
Originally Posted by oldjeep
There is a twisting spring...
Old Nov 10, 2010 | 07:10 AM
iimorgans's Avatar
iimorgans
If the weight is below the pivot point. That is how it acts as a counter-balance. I took my tailgat off last night and could not see a spring or torsion bar of any sort.
